Quality mesh
carlotacarlota Member Posts: 3
Hi!
These were my results of mesh quality, what does target skewness mean?
Would my quality be poor? how could i fix it?
  • RobRob UKPosts: 11,770Forum Coordinator
    Target is just a note to suggest a limit, and you've exceeded it. A max skew of 0.99999 means the cell is essentially flat (degenerate or may even have a negative volume) so must be fixed. At best the solver will fail fairly quickly, worst case the solver will take time to not converge and the result will be rubbish.
  • carlotacarlota Posts: 6Member
    Thank you very much, I will look for a tool that helps with the quality of the meshing, because I am working with very complex geometry.
    Right now I'm using the automatic method, you have any suggestions? I would appreciate your opinion.
    Automatic is fine, but you need to locate the bad cells and figure out what the problem is. It could be a rogue voxel in the scan conversion or a "thin" region that's not resolved.
  • DevinDevin Posts: 1Member
    edited October 15
    Automatic option is best option...but if u want to build a mesh in specific range of skewness, you can enter your limit there.. I don't to how much time it will take..
    You can also check this article regarding Skewness in mesh geraration section..https://www.cadsys25.com/2020/05/mesh-generation-and-cfd-steps.html
