Ansys Discovery Student - No License Found
As other users in this forum have reported, the Ansys Discovery Student version does not find any licenses after installing.
In my case, I've downloaded it and installed in a different drive (E:/) than the standard one (C:/). Other than that, I've followed every procedure correctly. Also, I have not found a student.lic file in my installation directory nor have I found the ANSYSLI_ELASTIC and ANSYSLI_LCP environment variables in my system.
Could someone help us all to find what's wrong?
  • Geo KarnosGeo Karnos Posts: 504Ansys Employee
    Under %TEMP%\.ansys, you should see a file named"
    licdebug.DISCOVERY.212.out
    Are there any errors listed in that file? Can you post the contents? Not the file as we are not permitted to open them.
  • LFSSLFSS Posts: 5Member
    edited October 5
    2021/10/01 21:29:36  ERROR        C:\Program Files\ANSYS Inc\v212\licensingclient\winx64\lmutil.exe does not exist
    2021/10/01 21:29:36  ERROR        "C:\Program Files\ANSYS Inc\v212\licensingclient\winx64\ansyscl.exe" does not exist.
    2021/10/01 21:29:36  CONNECT_ERROR    16167:1,16166:1                                   0/0/0/0  7952:DISCOVERY:luizf@DESKTOP-M6UHUJS:winx64        0:192.168.15.10
    Unable to connect to or start local server.
    2021/10/01 21:29:36  CUSTOMERNO                                                0/0/0/0  7952:DISCOVERY:luizf@DESKTOP-M6UHUJS:winx64        0:192.168.15.10
    Not connected to a server for Licensing Client Proxy actions.
    2021/10/01 21:29:36  CONNECT_ERROR    16079                                        0/0/0/0  7952:DISCOVERY:luizf@DESKTOP-M6UHUJS:winx64        0:192.168.15.10
    2021/10/01 21:29:36  CONNECT_ERROR    16308                                        0/0/0/0  7952:DISCOVERY:luizf@DESKTOP-M6UHUJS:winx64        0:192.168.15.10
    2021/10/01 21:29:36  CONNECT_ERROR    7                                          0/0/0/0  7952:DISCOVERY:luizf@DESKTOP-M6UHUJS:winx64        0:192.168.15.10
    2021/10/01 21:29:36  CONNECT_ERROR    0                                          0/0/0/0  7952:DISCOVERY:luizf@DESKTOP-M6UHUJS:winx64        0:192.168.15.10
    These are the errors present in the .out file.
    From what I've noticed, it's trying to pull a license file from a disk (C:) that was not used on the install procedure. Maybe redirecting it to search for the file in the correct disk should do the trick, but how can one do that?
    Just so that this post doesn't go into inactivity, I've found that my Ansys Discovery installation is referencing to a license file in another disk, not the one where it was installed. Finding a way to redirect the license check could be the solution to my and others' problems.
    What is the output from opening a DOS Command Prompt and typing in:
    set
    C:\Users\USER>set
    ALLUSERSPROFILE=C:\ProgramData
    AME=E:\Amesim\Amesim
    ANSYS212_DIR=E:\ANSYS Inc\ANSYS Student\v212\ANSYS
    ANSYS_SYSDIR=winx64
    ANS_OLD_ATTACH=1
    APPDATA=C:\Users\USER\AppData\Roaming
    AWP_LOCALE212=en-us
    AWP_ROOT212=E:\ANSYS Inc\ANSYS Student\v212
    CADOE_LIBDIR212=E:\ANSYS Inc\ANSYS Student\v212\CommonFiles\Language\en-us
    CDLMD_LICENSE_FILE=license.dat
    CommonProgramFiles=C:\Program Files\Common Files
    CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
    CommonProgramW6432=C:\Program Files\Common Files
    COMPUTERNAME=DESKTOP-M6UHUJS
    ComSpec=C:\Windows\system32\cmd.exe
    DriverData=C:\Windows\System32\Drivers\DriverData
    FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
    FPS_BROWSER_USER_PROFILE_STRING=Default
    HOMEDRIVE=C:
    HOMEPATH=\Users\USER
    ICEMCFD_SYSDIR=win64_amd
    I_MPI_SMPD_VERSION_CHECK=disable
    KEYSHOT_EXTERNAL_LICENSE_FOLDER=E:\Siemens\Solid Edge\Program
    LMS_LICENSE=C:\Users\USER\Documents\Amesim_License\LMS_NO_SERVER.lic
    LOCALAPPDATA=C:\Users\USER\AppData\Local
    LOGONSERVER=\\DESKTOP-M6UHUJS
    LSTC_LICENSE=ANSYS
    NUMBER_OF_PROCESSORS=8
    OneDrive=C:\Users\USER\OneDrive
    OneDriveConsumer=C:\Users\USER\OneDrive
    OS=Windows_NT
    Path=E:\Amesim\Amesim;E:\Amesim\Amesim\win64;E:\Amesim\Amesim\win32;E:\Amesim\Amesim\sys\mingw32\bin;E:\Amesim\Amesim\sys\python\win64;E:\Amesim\System Architect\win64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Users\USER\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\USER\AppData\Local\Programs\Python\Python39\;C:\Users\USER\AppData\Local\Microsoft\WindowsApps;
    PROCESSOR_ARCHITECTURE=AMD64
    PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 94 Stepping 3, GenuineIntel
    PROCESSOR_LEVEL=6
    PROCESSOR_REVISION=5e03
    ProgramData=C:\ProgramData
    PROMPT=$P$G
    PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules
    PUBLIC=C:\Users\Public
    SESSIONNAME=Console
    SE_LICENSE_SERVER=e:\Siemens\Solid Edge\Preferences\SELicense.lic
    SYSSYN=E:\Amesim\System Architect
    SystemDrive=C:
    SystemRoot=C:\Windows
    TEMP=C:\Users\USER\AppData\Local\Temp
    TMP=C:\Users\USER\AppData\Local\Temp
    USERDOMAIN=DESKTOP-M6PAHUJS
    USERDOMAIN_ROAMINGPROFILE=DESKTOP-M6PAHUJS
    USERNAME=USER
    USERPROFILE=C:\Users\USER
    windir=C:\Windows
  • Patrick3463Patrick3463 Posts: 6Member
    I have the exact same issue.
    2021/10/20 23:00:44  ERROR        C:\Program Files\ANSYS Inc\v212\licensingclient\winx64\lmutil.exe does not exist
    2021/10/20 23:00:44  ERROR        "C:\Program Files\ANSYS Inc\v212\licensingclient\winx64\ansyscl.exe" does not exist.
    2021/10/20 23:00:44  CONNECT_ERROR    16167:1,16166:1
    etc.
    If anyone has any solutions to this. Please let us know. I have installed it on C drive so it should be pointing to correct path.
    This is most likely a faulty version that was released without some vital licensing information. I've tried everything since I first downloaded this on the last week of September.
    If anyone could give any kind of feedback to all of us in trouble, that'd be swell.
  • capitaniocapitanio Posts: 1Member
    edited October 27
    I solved it with the following steps:
    1 - uninstall Ansys
    2 - clear the Ansys folder (where you've installed it)
    3 - clear the Ansys cache ( here some previous configs are set, which can causes some troubles) https://www.youtube.com/watch?v=EiwOxiMgqE0
    4 - reinstall Ansys
    5 - update virtual environments variables (you must certify that the path of the application is correct, for me the program was calling an old path from an old Ansys Version)
  • vganorevganore Pune, IndiaPosts: 714Admin
    Guys, the license issue in Discovery Student has been resolved. If you are facing this issue then please uninstall the product, redownload from the website and install. The updated product should run fine.
    Another solution if @vganore solution isnt working is installing the R1 version which has proper licence files. I had 2.1 installed and tried so many things which didnt help. I installed the R1 and suddenly both started working. Licence picked up. All working. Tried it on my laptop too. Same story. R2.1 on its own, no licence, then install R1 and both work again.
