Ansys Student 2021 R2: Fluent application failed to start error
This error seems to be usual. I've already searched everywhere and can't reach a solution.
When installing application I've faced a problem related to the prerequisites (failed to install). I've installed one by one manually but the Ansys app wouldn't load. I've managed to change some .dll files, following a procedure find on the internet and everything went well with static structural.
But now, starting a Fluent project, I got the error: Fluent application failed to start.
I've already re-installed Ansys, turned off Firewall, re-installed prerequisites as administrator, tried to run Fluent standalone, but without success.
Can someone point me a direction to solve this?
Thanks in advance.
  • Geo KarnosGeo Karnos Posts: 504Ansys Employee
    When you run Fluent Standalone, do you receive an error in the output window?
    If so, can you post the output window window?
  • P_e_a_RP_e_a_R Posts: 7Member
    @Geo Karnos thanks for your input in this subject.
    When I try to launch the app from the laucher, thats the error (missing .dll) I get!
    Does this help?
    check the size of the downloaded installation file to verify that it is the same as on the download site.
    That dll file should exist in 3 places:
    C:\Program Files\ANSYS Inc\ANSYS Student\v212\fluent\ntbin\win64
    C:\Program Files\ANSYS Inc\ANSYS Student\v212\commonfiles\fluids\lib-hdf18\winx64
    C:\Program Files\ANSYS Inc\ANSYS Student\v212\commonfiles\fluids\lib\winx64
    If it does not, I would uninstall and reinstall the software by right-clicking on setup.exe and choosing run as administrator
    Checked downloaded file size: Its OK, 7.42GB
    .dll exist in the 3 indicated places: OK
    I'd previously installed Ansys student as admin twice before posting here. Didn't solved the problem.
    Is there anything I should look for ? =/
    Open a Dos command pro mpt and type in:
    set
    Please send me the output
    Here is goes:
    ALLUSERSPROFILE=C:\ProgramData
    ANSYS212_DIR=C:\Program Files\ANSYS Inc\ANSYS Student\v212\ANSYS
    APPDATA=C:\Users\Delete\AppData\Roaming
    AWP_LOCALE212=en-us
    AWP_ROOT212=C:\Program Files\ANSYS Inc\ANSYS Student\v212
    CADOE_LIBDIR212=C:\Program Files\ANSYS Inc\ANSYS Student\v212\CommonFiles\Language\en-us
    CLASSPATH=C:\Program Files\Portugal Identity Card\
    CommonProgramFiles=C:\Program Files\Common Files
    CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
    CommonProgramW6432=C:\Program Files\Common Files
    COMPUTERNAME=DESKTOP-IK9P7GU
    ComSpec=C:\WINDOWS\system32\cmd.exe
    DriverData=C:\Windows\System32\Drivers\DriverData
    FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
    FPS_BROWSER_USER_PROFILE_STRING=Default
    HOMEDRIVE=C:
    HOMEPATH=\Users\Delete
    INTEL_LICENSE_FILE=C:\Program Files (x86)\Common Files\Intel\Licenses
    I_MPI_ROOT=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.3.210\windows\mpi
    LOCALAPPDATA=C:\Users\Delete\AppData\Local
    LOGONSERVER=\\DESKTOP-IK9P7GU
    LSTC_LICENSE=Ansys
    MSMPI_BENCHMARKS=C:\Program Files\Microsoft MPI\Benchmarks\
    MSMPI_BIN=C:\Program Files\Microsoft MPI\Bin\
    NUMBER_OF_PROCESSORS=4
    OneDrive=C:\Users\Delete\OneDrive
    OS=Windows_NT
    Path=C:\Program Files\Microsoft MPI\Bin\;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.3.210\windows\mpi\intel64\bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Rockwell Software\RSCommon;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Thorlabs\Thorlabs OSA;C:\Program Files\Thorlabs\Thorlabs OSA\bin;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\;C:\Program Files\IVI Foundation\VISA\Win64\Bin\;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin;C:\Program Files\Portugal Identity Card\;C:\Users\Delete\AppData\Local\Microsoft\WindowsApps;
    PROCESSOR_ARCHITECTURE=AMD64
    PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 61 Stepping 4, GenuineIntel
    PROCESSOR_LEVEL=6
    PROCESSOR_REVISION=3d04
    ProgramData=C:\ProgramData
    PROMPT=$P$G
    PSModulePath=C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules\
    PUBLIC=C:\Users\Public
    P_SCHEMA=C:\Program Files\ANSYS Inc\ANSYS Student\v212\AISOL\CADIntegration\Parasolid\PSchema
    SESSIONNAME=Console
    SystemDrive=C:
    SystemRoot=C:\WINDOWS
    TEMP=C:\Users\Delete\AppData\Local\Temp
    TMP=C:\Users\Delete\AppData\Local\Temp
    USERDOMAIN=DESKTOP-IK9P7GU
    USERDOMAIN_ROAMINGPROFILE=DESKTOP-IK9P7GU
    USERNAME=Delete
    USERPROFILE=C:\Users\Delete
    VXIPNPPATH=C:\Program Files (x86)\IVI Foundation\VISA\
    VXIPNPPATH64=C:\Program Files\IVI Foundation\VISA\
    windir=C:\WINDOWS
    Thanks!
    I would try changing your PATH environment variable so that it starts with:
    Meaning, I would cut the following and paste it at the end of the PATH variable value:
    Following your recommendations, I've changed the PATH variable, according to the images.
    Didn't solved unfortunately.
    When trying to launch fluent standalone, that error shown up. Little bit different, but similar to before.
  • CChavez27CChavez27 Posts: 1Member
    Hello!
    I am having a similar issue, when I open Fluent from workbench I also got the error: Fluent application failed to start.
    I've also already re-installed Ansys, turned off Firewall, re-installed prerequisites as administrator without success.
    However, when I open the Fluent standalone it opens perfectly
    When reviewing the fluent console, notice that the following error is shown:
    "Error: Cortex received a fatal signal (SEGMENTATION VIOLATION). Error Object: ()"
    Would someone please point me a direction to solve this?
    Thanks in advance.
  • andremendesandremendes Posts: 8Member
    hey @P_e_a_R , i have a very similar error with fluent. Did you find out how to solve it?
    Hi, André,
    Unfortunately I didn't reach the solution for the problem.
    Hello All,
    Can you please check the driver for your graphics card to verify that it is the latest driver available.
    Run DXDIAG
    This will show you the driver date on the Display tab.
    An old example:
    Thank You.
    dll errors of this nature are very difficult to troubleshoot.
    The issues could be due to dlls of an older version on the Windows\System32 directory or not having full administrator privileges when installing(Right-click ->run as administrator)
    Microsoft has a tool that may help see where the issue is. It is called : procmon
    @Geo Karnos ,
    Thanks for your effort in trying to help the situation.
    The driver is recent (2019) and manufacturer seems not to provide a newer update. All the installation was done as admin.
    For now I will just quit this subject and try to install another windows version in the future, expecting it will solve the problem.
    Thank you very much anyways.
  • clean uninstall your antivirus and rerun the workbench. problem solved for me. my antivirus is not allowing fluent to access the network.
