Workbench 19.2 Unexpected Error
aschefaschef Member Posts: 1
Hello Everyone,
After Installing Ansys Student as Admin and starting Workbench 19.2 (from Start and from the installation folder) as Admin, too, I get this error message.
I tried changing my computername and system language to english (us), redownload, -installing and -starting but nothing works.
Thanks in advance.
Alex
  • JakeCJakeC Posts: 302Forum Coordinator
    edited October 2018
    Hi Alex,
    It sounds like there may be a dll conflict in your path.
    Please try the following:
    Start -> type in cmd -> click on the command prompt
    Enter the following commands, and please adjust as necessary to match your machine:
    set Path=C:\windows\system32;C:\windows;C:\windows\System32\Wbem;
    cd "c:\program files\ansys inc\v192\Framework\bin\win64\"
    runwb2
    Please let us know if that helps.
    Thank you,
    Jake
  • aschefaschef Posts: 5Member
    edited October 2018
    Hello Jake,
    thank you for your quick reply, but unfortunately it still doesn't work. (same error)
    edited October 2018
    Hi Alex,
    In the command prompt, please type "set" and press enter.
    Then post a screenshot of the results.
    Also please try opening windows file explorer and paste the following into the path/address bar at the top:
    %APPDATA%\ansys
    Rename the v192 directory to be v192_old
    Next click on Start -> Type in DxDiag.exe -> Click on DxDiag
    Post a screenshot of each of the tabs.
    Next open an Admin Command Prompt Start -> type cmd -> Right click on Command Prompt -> Run As Administrator
    Enter the following commands:
    cd \windows\system32\
    regsvr32.exe ole32.dll
    regsvr32.exe atl.dll
    regsvr32.exe oleaut32.dll
    regsvr32.exe scrrun.dll
    regsvr32.exe jscript.dll
    regsvr32.exe vbscript.dll
    Next click on start -> Ansys 19.2 -> Product and CAD configuration
    Click on "Check for Required Prerequisites" and post a screenshot of the results.
    Click on "Install Required Prerequisites" (and follow the prompts)
    Click on "Add >NET Security Exception"Click on Configure Products and CADS (and follow the prompts)
    Now try running Workbench again.
    If that doesn't work, please right click on the Workbench shortcut in the start menu and select "Run As Administrator" and see if that works.
    Thank you,
    Jake
    edited October 2018
    Hi Jake,
    "Set" output in cmd:
    Output of
    DxDiag_1:
    DxDiag_2:
    DxDiag_3:
    DxDiag_4:
    Required Prerequisites:
    Sadly, still the same error.
    Thank You,
    Alex
  • tsiriakstsiriaks 3240 El Camino Real #290, Irvine, CA 92602Posts: 3,071Forum Coordinator
    edited October 2018
    Hi aschef ,
    Just for a kick, if you run this directly
    C:\Program Files\ANSYS Inc\ANSYS Student\v192\commonfiles\IronPython\ipy.exe
    Do you see a similar error ?
    If so, there is something on the systems that is messing with IronPython
    I'm not sure if it's related but it might be worth trying to uninstall that IronRuby and see if it makes any difference.
    Thank you,
    Win
    edited October 2018
    Hi Win,
    yes, there was a similar error and yes it was related! After deinstalling IronPython, Ansys started normally.
    Thank you very much!
    Alex
    edited October 2018
    Perfect !
    Thank you for the update.
    Win
  • Thank you so much sir, I'm trying to solve this error from many days, surf all related content, seen every video related but finally your help works thank you thank you so much sir....
