Please use ANSLIC_ADMIN to setup your license server.
Patrick3463Patrick3463 Member Posts: 1
So ive been trying to install the discovery student. Initially I kept getting the issue of:
"2021/10/20 23:00:44  ERROR        C:\Program Files\ANSYS Inc\v212\licensingclient\winx64\lmutil.exe does not exist
2021/10/20 23:00:44  ERROR        "C:\Program Files\ANSYS Inc\v212\licensingclient\winx64\ansyscl.exe" does not exist.
2021/10/20 23:00:44  CONNECT_ERROR    16167:1,16166:1
etc."
I resolved this by creating said folders at said location "C:\Program Files\ANSYS Inc\v212\licensingclient\winx64", finding those missing files in the installation file and putting them as requested by the log.
That solved some. But I cannot find anywhere this file. If anyone knows the location of it. let me know
2021/10/25 23:14:33  ERROR        "C:\Program Files\ANSYS Inc\v212\licensingclient\winx64\ansyscl.exe" does not exist.
2021/10/25 23:14:33  CONNECT_ERROR    7                                          0/0/0/0  17804:DISCOVERY:Patri@DESKTOP-FO5JBBR:winx64        0:192.168.0.10
Unable to connect to or start local server.
2021/10/25 23:14:33  CONNECT_ERROR    0                                          0/0/0/0  17804:DISCOVERY:Patri@DESKTOP-FO5JBBR:winx64        0:192.168.0.10
  • Patrick3463Patrick3463 Posts: 6Member
    so i found the file in the 2020 version easily. I tried the 2020 file in the 2021 and this is the result:
    2021/10/25 23:29:28  CLIENT_CONNECT                                              1/1/0/1  14256:DISCOVERY:Patri@DESKTOP-FO5JBBR:winx64        0:192.168.0.10
    Your version of the ANSYS license client software is out of date. Please refer to Licensing Error Messages in the Troubleshooting section of the ANSYS, Inc. Licensing Guide.
         The version of the license client 56352@DESKTOP-FO5JBBR [2.1.1] must be greater or equal to the client DISCOVERY version [2.2.1].
    2021/10/25 23:29:28  ERROR        Your version of the ANSYS license client software is out of date. Please refer to Licensing Error Messages in the Troubleshooting section of the ANSYS, Inc. Licensing Guide.
    2021/10/25 23:29:28  CONNECT_ERROR    0                                          0/0/0/0  14256:DISCOVERY:Patri@DESKTOP-FO5JBBR:winx64        0:192.168.0.10
    It works BUT its an old licence and this wont work. So whoever works there, can you please help me find the missing file in the 2021 version? Thank you
  • Geo KarnosGeo Karnos Posts: 504Ansys Employee
    @Patrick3463
    Try the following:
    In the extracted free student download, you should see a directory named:
    clclient
    under this directory, you should see a file named: WINX64.7z
    Extract this file to: C:\Program Files\ANSYS Inc\ANSYS Student\v212
    This should create a directory named: licensingclient which will contain a directory named: winx64
    The missing executables should now exist under that directory.
    Now try and run.
    edited November 3
    I just solved it by installing the R1 2021. It had the proper installation files and worked first time. Once the R1 licence server files was installed, the r2.1 worked fine. I tested it with 3 computers. All have the same story. No licence in 2.1, but there is a licence file in r1. Once you install both R1 and R2.1. Both work. So you should probably install your latest on a brand new pc without previous files hidden in system files and troubleshoot your installer.
    @Geo Karnos
