Fluent doesn't work through Workbench
gmeira21gmeira21 Member Posts: 2
My Fluent application will not work when I open it through Workbench. It does open but I can't seem to use it at all, but if I open Fluent independently it works nicely. Also when I open Fluent trough Workbench it won't close so I have to forcefully shut it down and after that it shows me the following error "The FLUENT application failed to initialize".
I've reinstalled ANSYS multiple times, even different versions. Right now I'm using 2021R2.
I've searched in multiple disscussions and I can't find an answer to this problem.
Is there a way to use Fluent through the Workbench?
Thank you,
Gonçalo Meira
  • RobRob UKPosts: 11,714Forum Coordinator
    One for @Geo Karnos or @mmadore but if you're using VPN try turning that off. The other option on the launcher is to set the IP interface to 127.0.0.1 and see if that helps.
  • gmeira21gmeira21 Posts: 8Member
    I've already tried both and they dont work unfortunately.
  • mmadoremmadore Posts: 1,056Ansys Employee
    @gmeira21 Can you please screenshot the Launcher settings for each tab, both for launching from Workbench and standalone?
    Can you try changing the Working Directory to a different directory outside of the Program Files? Perhaps create a C:\Working directory and select that? This may be caused by failure to access the directory properly.
    @mmadore Sorry, I should've labeled the pictures, my bad. The first 5 pictures are form the standalone Fluent Launcher, the last one is from the Workbench Fluent Launcher. Here is another one from Workbench for more context.
    I can't change the working directory on Workbench directly, but it wasn't this one before, I must've changed it somehow. It was firstly in Program Files I believe.
    Can you share the text from the file %TEMP%\.ansys\licdebug.FLUENT.212.out?
    @mmadore
    2021/10/31 20:37:26  CLIENT_CONNECT                                              3/3/3/3  10636:FLUENT:greis@Portátil21:winx64            7404:192.168.1.105
    2021/10/31 20:37:26  NEW_CONNECTION   Connected to Licensing Client Proxy server: 50008@127.0.0.1.
    2021/10/31 20:37:26  CHECKOUT      cfd_solve_level2        21.2 (2021.0512)       1/1/1/1         3/3/3/3  10636:FLUENT:greis@Portátil21:winx64            7404:192.168.1.105
    2021/10/31 20:37:26  CHECKOUT      cfd_solve_level1        21.2 (2021.0512)       1/1/1/1         3/3/3/3  10636:FLUENT:greis@Portátil21:winx64            7404:192.168.1.105
    2021/10/31 20:37:26  CHECKOUT      cfd_base            21.2 (2021.0512)       1/1/1/1         3/3/3/3  10636:FLUENT:greis@Portátil21:winx64            7404:192.168.1.105
    2021/10/31 20:37:26  CHECKOUT      FEAT_CFD_BASE          21.2 (2021.0512)      1/1/1/-1         3/3/3/3  10636:FLUENT:greis@Portátil21:winx64            7404:192.168.1.105
    2021/10/31 20:37:26  CHECKOUT      FEAT_CFD_SOLVE_LEVEL1      21.2 (2021.0512)      1/1/1/-1         3/3/3/3  10636:FLUENT:greis@Portátil21:winx64            7404:192.168.1.105
    2021/10/31 20:37:26  CHECKOUT      FEAT_CFD_SOLVE_LEVEL2      21.2 (2021.0512)      1/1/1/-1         3/3/3/3  10636:FLUENT:greis@Portátil21:winx64            7404:192.168.1.105
    2021/10/31 20:37:30  CHECKOUT      11072_port_til21-greis-20280-001382_50008@127.0.0.1    21.2 (2021.0512)       1/1/1/1         3/3/3/3  10636:FLUENT:greis@Portátil21:winx64            7404:192.168.1.105
    2021/10/31 21:00:12  CLIENT_CONNECT                                              3/3/3/3  9736:FLUENT:greis@Portátil21:winx64            7476:192.168.1.105
    2021/10/31 21:00:12  NEW_CONNECTION   Connected to Licensing Client Proxy server: 50628@127.0.0.1.
    2021/10/31 21:00:12  CHECKOUT      cfd_solve_level2        21.2 (2021.0512)       1/1/1/1         3/3/3/3  9736:FLUENT:greis@Portátil21:winx64            7476:192.168.1.105
    2021/10/31 21:00:12  CHECKOUT      cfd_solve_level1        21.2 (2021.0512)       1/1/1/1         3/3/3/3  9736:FLUENT:greis@Portátil21:winx64            7476:192.168.1.105
    2021/10/31 21:00:12  CHECKOUT      cfd_base            21.2 (2021.0512)       1/1/1/1         3/3/3/3  9736:FLUENT:greis@Portátil21:winx64            7476:192.168.1.105
    2021/10/31 21:00:12  CHECKOUT      FEAT_CFD_BASE          21.2 (2021.0512)      1/1/1/-1         3/3/3/3  9736:FLUENT:greis@Portátil21:winx64            7476:192.168.1.105
    2021/10/31 21:00:12  CHECKOUT      FEAT_CFD_SOLVE_LEVEL1      21.2 (2021.0512)      1/1/1/-1         3/3/3/3  9736:FLUENT:greis@Portátil21:winx64            7476:192.168.1.105
    2021/10/31 21:00:12  CHECKOUT      FEAT_CFD_SOLVE_LEVEL2      21.2 (2021.0512)      1/1/1/-1         3/3/3/3  9736:FLUENT:greis@Portátil21:winx64            7476:192.168.1.105
    2021/10/31 21:00:16  CHECKOUT      12608_port_til21-greis-7104-001393_50628@127.0.0.1    21.2 (2021.0512)       1/1/1/1         3/3/3/3  9736:FLUENT:greis@Portátil21:winx64            7476:192.168.1.105
    2021/11/02 12:22:48  CLIENT_CONNECT                                              3/3/3/3  14512:FLUENT:greis@Portátil21:winx64            7496:192.168.1.164
    2021/11/02 12:22:48  NEW_CONNECTION   Connected to Licensing Client Proxy server: 63471@127.0.0.1.
    2021/11/02 12:22:48  CHECKOUT      cfd_solve_level2        21.2 (2021.0512)       1/1/1/1         3/3/3/3  14512:FLUENT:greis@Portátil21:winx64            7496:192.168.1.164
    2021/11/02 12:22:48  CHECKOUT      cfd_solve_level1        21.2 (2021.0512)       1/1/1/1         3/3/3/3  14512:FLUENT:greis@Portátil21:winx64            7496:192.168.1.164
    2021/11/02 12:22:48  CHECKOUT      cfd_base            21.2 (2021.0512)       1/1/1/1         3/3/3/3  14512:FLUENT:greis@Portátil21:winx64            7496:192.168.1.164
    2021/11/02 12:22:48  CHECKOUT      FEAT_CFD_BASE          21.2 (2021.0512)      1/1/1/-1         3/3/3/3  14512:FLUENT:greis@Portátil21:winx64            7496:192.168.1.164
    2021/11/02 12:22:48  CHECKOUT      FEAT_CFD_SOLVE_LEVEL1      21.2 (2021.0512)      1/1/1/-1         3/3/3/3  14512:FLUENT:greis@Portátil21:winx64            7496:192.168.1.164
    2021/11/02 12:22:48  CHECKOUT      FEAT_CFD_SOLVE_LEVEL2      21.2 (2021.0512)      1/1/1/-1         3/3/3/3  14512:FLUENT:greis@Portátil21:winx64            7496:192.168.1.164
    2021/11/02 12:22:52  CHECKOUT      10584_port_til21-greis-21460-001390_63471@127.0.0.1    21.2 (2021.0512)       1/1/1/1         3/3/3/3  14512:FLUENT:greis@Portátil21:winx64            7496:192.168.1.164
    2021/11/02 12:23:17  CLIENT_CONNECT                                              3/3/4/4  11072:FLUENT:greis@Portátil21:winx64            852:192.168.1.164
    2021/11/02 12:23:17  NEW_CONNECTION   Connected to Licensing Client Proxy server: 63471@127.0.0.1.
    2021/11/02 12:23:18  CHECKOUT      cfd_solve_level2        21.2 (2021.0512)       1/1/1/1         3/3/4/4  11072:FLUENT:greis@Portátil21:winx64            852:192.168.1.164
    2021/11/02 12:23:18  CHECKOUT      cfd_solve_level1        21.2 (2021.0512)       1/1/1/1         3/3/4/4  11072:FLUENT:greis@Portátil21:winx64            852:192.168.1.164
    2021/11/02 12:23:18  CHECKOUT      cfd_base            21.2 (2021.0512)       1/1/1/1         3/3/4/4  11072:FLUENT:greis@Portátil21:winx64            852:192.168.1.164
    2021/11/02 12:23:18  CHECKOUT      FEAT_CFD_BASE          21.2 (2021.0512)      1/1/1/-1         3/3/4/4  11072:FLUENT:greis@Portátil21:winx64            852:192.168.1.164
    2021/11/02 12:23:18  CHECKOUT      FEAT_CFD_SOLVE_LEVEL1      21.2 (2021.0512)      1/1/1/-1         3/3/4/4  11072:FLUENT:greis@Portátil21:winx64            852:192.168.1.164
    2021/11/02 12:23:18  CHECKOUT      FEAT_CFD_SOLVE_LEVEL2      21.2 (2021.0512)      1/1/1/-1         3/3/4/4  11072:FLUENT:greis@Portátil21:winx64            852:192.168.1.164
    2021/11/02 12:23:21  CHECKOUT      10584_port_til21-greis-21460-001406_63471@127.0.0.1    21.2 (2021.0512)       1/1/1/1         3/3/4/4  11072:FLUENT:greis@Portátil21:winx64            852:192.168.1.164
    @gmeira21 I apologize for the delay in response. Can you please post a screenshot of the FUNCTIONAL Fluent window, showing the very top of the TUI section?
