Matlab and Ansys Workbench -aas coupling
I am working to connect Matlab 2016b with Ansys Workbench.  I have downloaded the -aas toolbox and installed it into matlab.  I have successfully captured the fluent coupling and the Mechanical APDL coupling.  There are instructions with the toolbox to couple with workbench but I cannot seem to get it to work.  I have attached the aas instruction sheet.
Following the instruction on page 4 of the attached PDF, I went into to command prompt and went to run the "runwb2" .bat file with the extensions the instructions suggest as an example.  Not sure how to determine if the example write out is appropriate or not.
Specifically I need to create a aaS_Wbld.txt file that will allow the link to happen.  Everything I can find states that the file needs to be made but not how to get it.
I have already reviewed the popular ansys blog How to Make Matlab apps.  It is not helpful in determining how to actually get the aas keys made, it just states to go make them.
Any help on this would be greatly appreciated.
  • KremellaKremella Admin
    edited October 2018
    As ANSYS employees, we will not be able to open any attached files. Could you please post the instructions you are talking about as screenshots? If this does not work, could you please point us to the link where you found this document? We would like to understand your question better.
    If you have not see these already, here are some resources which might be of some help to you.
    https://studentcommunity.ansys.com/thread/download-matlab-toolbox-ansysaas/
    https://www.ansys.com/blog/how-to-make-matlab-apps-for-ansys/
    Also, I am moving this post to 'Structural Mechanics' for more traction.
    I hope this helps.
    Best Regards,
  • aacius1aacius1 Member
    edited October 2018
    Thanks for the response Karthik
    You're first link was helpful to me earlier today as it explains how to find Fluent and MAPDL.  The suggestions by the Admin at the end of the thread  on using workbench were how to call workbench in matlab.  You'll notice step 3 of the admins suggestions calls aaS-Wbld.txt.  That's the file I need to get Ansys to create.  I have already gotten MAPDL and Fluent to make respective files for their uses.
    Unfortunately the 2nd link only states that the .txt file Im trying to get should be made, not how to make it
    The instructions state that for workbench you should add the below to the standard workbench command
    -I -E "with open('aaS_Wbld.txt','w') as file:file.write(Server.StartServer('localhost',0,9000,9200))"
    I assumed that this meant I should call workbench from the windows command prompt.  I used the following line...
    C:Program FilesANSYS Incv162FrameworkinWin64
    ubwb2 -I -E "with open('aaS_Wbld.txt','w') as file:file.write(Server.StartServer('localhost',0,9000,9200))"
    I found that this would open workbench but I would receive an error that stated there was a unexpected syntax ":" and would point at 'w' near the beginning of the extra command.
    Ansys Student also has youtube files on how to get MAPDL and Fluent set up but not workbench.  If we figure this out, I'm sure it would help a lot of people if another video was added
    Aric
  • Gary_SGary_S Member
    edited October 2018
    Example:
    Create a batch file in your home folder, i.e. C:usersjsmith
    Double click the batch file. WB will start, and the aaS_WbId.txt will be created
    Note: The 2nd command is a single line.
    myRunWB.cmd
    @echo off
    "C:Program FilesANSYS Incv190FrameworkinWin64
    unwb2.exe" -I -E "with open('aaS_WbId.txt','w') as file:file.write(Server.StartServer('localhost',0,9000,9200))"
    edited October 2018
    Hey Gary_S
    Hopefully you won't mind but I have another question since you got me past that first roadblock. Once I open up Workbench with this, and follow the method of connecting matlab to workbench by putting the following into Matlab:
    orb=initialize_orb()
    load_ansys_aas;
    actwbserver(CUsers/me/aaS_WbId.txt')
    Everything seems to be going fine.
    When I enter in the next commands as suggested by the instructions I get JAVA errors.  The command and error are below.
    Whenever I use execwbcommand(' ') I get the same error.  My understanding was that it should work in a similar way to regular ansys script commands.
    Matlab error
  • MeruMeru Member
    edited April 2019
    Example:
    myRunWB.cmd
    @echo off
    while running this bat file I am able to create a txt file called aaS_WbId.txt but this file is blank and there is no key in it. could you help me in overcoming this hurdle?
    also when I initiate connection with in matlab by actwbserver('aaS_WbId.txt') command I am getting a java error
    could you please help me
    Thank you
    Meru
