Partitioning with journal file
bujarpbujarp Member Posts: 3
I used tihs command in TUI to try a partition without going to different zones.
/parallel/partition/method/principal-axes 40
/parallel/partition/set/across-zones
After the second commant Fluent says that with Metis it isn't possible to change across zones, allthough I used the command before.
I want to try, if disabling across zones can lead to better simulation time.
Thank you
«1
    It's unlikely to help, but will depend on the rest of the model. How many cells have you got, and how many zones? Are those zones moving?
  • bujarpbujarp Posts: 24Member
    16 cell zones. There are two sliding meshes and also periodic boundaries. Maybe the a partition boundary, which is cutting the rotational zone can lead to large communication time?
    Mesh Info:218718 nodes and 1110183 elements. My question was more about the TUI.
    Thanks anyway
    With around 1 million cells and non-conformals for sliding mesh I'd not go over about 10 partitions for efficient use of the cores. You'll still see speed up beyond that.
    Re the two commands, why are you partitioning and then setting the partition across boundaries? Also, whilst journals are very powerful it's usually easier to set up a model locally, partition manually and then send it off to the cluster to run.
    Thanks. There is also another problem that the if I simulate with 1 Node(20 tasks per node--> so 20 partitions) I get this error message:
    =  BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
    =  PID 4882 RUNNING AT cstd02-049
    =  EXIT CODE: 9
    =  CLEANING UP REMAINING PROCESSES
    =  YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
      Intel(R) MPI Library troubleshooting guide:
          https://software.intel.com/node/561764
    When simulating with one node it uses too much memory:
    > time        kbmemused
    > 10:40:01 AM 11605588
    > 10:50:01 AM 14114168
    > 11:00:01 AM 16619788
    > 11:10:01 AM 18385440
    > 11:20:01 AM 20677200
    > 11:30:01 AM 22551200
    > 11:40:01 AM 24563312
    > 11:50:01 AM 27044424
    > 12:00:01 PM 28601752
    > 12:10:02 PM 30850688
    > 12:20:01 PM 32915072
    > 12:30:01 PM 35065452
    > 12:40:01 PM 36657816
    > 12:50:01 PM 38874056
    > 01:00:01 PM 41414584
    > 01:10:01 PM 43445944
    > 01:20:01 PM 44990388
    > 01:30:01 PM 47385076
    > 01:40:01 PM 49660092
    > 01:50:01 PM 51335148
    > 02:00:01 PM 53959052
    > 02:10:01 PM 56032252
    > 02:20:01 PM 58121960
    > 02:30:01 PM 59675572
    > 02:40:01 PM 61839556
    Then there is not ennough RAM availlable for that problem.
    If i simulate with 2Nodes (40 partitions) the simulation is running fine.
    I very appreciate your help.
    What solver models have you got turned on? 1M cells shouldn't use much more than 3GB RAM unless you're running chemistry or multiphase.
    It is multiphase Eulerian model. For turbulence I used mixture Real. kepsilon model.
    2 phase Euler with no chemistry shouldn't need any more than 4GB RAM, so I'm not sure why it's failing. Can you get more info from IT to see if it's something on their side.
    I talked with someone from IT but he said it has more something to do with Fluent. There is also one thing in Fluent, which I want to ask, because you talked about chemistry:
    The species model in Fluent is deactivated, nevertheless I get the Warnings:
    Warning: Create_Material: (water-liquid . species-mixture) already exists
    and
    Warning: Create_Material: (buac-liquid-tracer . species-mixture) already exists
    around 30 times. That's because I wanted to activate the species model but then deactivated it again. But the problem with the simulation time was also present before I think.
    A repeat like that tends to be parallel nodes trying to open something. If you turned species off, the mixture should be kept in the case but isn't available as an option. I have seen another case with stuck phase/species and wonder if you've glitched the scheme call when turning the model off. Check what species are present in the materials and see what is used in the cell zone(s).
    For both phase materials it looks fine, I think. There is no mixture defined.
    Not sure, there's something not set up correctly somewhere. How many materials are there?
    The problem is that you cannot see that in the GUI. But from the TUI it is visible.Deleting is not possible. I decided to make a new fluent setup and then I am sure that no only desired material is activated.
    I am not sure if then the simulation is getting faster, but I hope so.
    Something's very scrambled in the case. It's probably recoverable but it'll be quicker for you to rebuild from the mesh file.
    It's me again. I still have the same problems with the too long simulation time. I use periodic boundaries with periodic repeats and sliding mesh. Any ideas? That#s the only problem I have now. The thing with the species models is resolved. I only have two phases there. The periodic offset is 120 degree.
    Define "too long", CFD runs typically take hours or even weeks depending on what you're modelling.
    9 hours for 1 second simulation time (timestep=0.001s; no. of timesteps 1000).
    Two sliding meshes
    I use a HPC cluster. I simulate 2 Nodes with one task per node. I don't know why it takes so long.
    I use Eulerian apprach two phases and the real. k- epsilon model.
    I simulate with ca. 1 Mio cells
    Thats the file for the cluster starting the job
    #!/bin/bash -l
    #SBATCH --job-name 181121_2
    #SBATCH --partition=long
    #SBATCH --time 18:00:00
    ##SBATCH --exclusive
    #SBATCH --constraint="[cstd01|cstd02]"
    #SBATCH --mem=60000
    #SBATCH --nodes=2
    #SBATCH --ntasks-per-node=20
    #SBATCH -e error_file.e
    #SBATCH -o output_file.o
    ## Gather the number of nodes and tasks
    numnodes=$SLURM_JOB_NUM_NODES
    numtasks=$SLURM_NTASKS
    mpi_tasks_per_node=$(echo "$SLURM_TASKS_PER_NODE" | sed -e 's/^\([0-9][0-9]*\).*$/\1/')
    ## store hostname in txt file
    srun hostname -s > slurmhosts.$SLURM_JOB_ID.txt
    ## calculate slurm task count
    if [ "x$SLURM_NPROCS" = "x" ]; then
       if [ "x$SLURM_NTASKS_PER_NODE" = "x" ];then
          SLURM_NTASKS_PER_NODE=1
       fi
       SLURM_NPROCS=`expr $SLURM_JOB_NUM_NODES \* $SLURM_NTASKS_PER_NODE`
    fi
    export OMP_NUM_THREADS=1
    export I_MPI_PIN_DOMAIN=omp:compact # Domains are $OMP_NUM_THREADS cores in size
    export I_MPI_PIN_ORDER=scatter # Adjacent domains have minimal sharing of caches/sockets
    # Number of MPI tasks to be started by the application per node and in total (do not change):
    np=$[${numnodes}*${mpi_tasks_per_node}]
    # load necessary modules
    module purge
    module add intel/mpi/2019.1
    module add fluent/2021R1
    # run the fluent simulation
    fluent 3ddp -ssh -t$np -mpi=intel -pib -cnf=slurmhosts.$SLURM_JOB_ID.txt -g -i journal.jou
    # delete temp file
    rm slurmhosts.$SLURM_JOB_ID.txt
