Simulating the working principle of cylindrical heat pipe with wick stracture?
heat pipe is hallow tube with both ends closed and charged with working fluid at optimum fill ratio.tube surface is divided into three sections heater,adiabatic and condensor.heat input is given at heater section(constant temp)and condensor is also maintained at constant temperature.liquid is evaporated at heater section and vapour travells towards condensor section through core section and it is condensed.condensed liquid from bottom is lifted to heater section by capillary action generated by the wick stracture(i.e.copper porous media),which is wrappped around the inner pheriphery of heat pipe . It inludes process like phase change of working fluid (evaporation and condensation)and flow through porous media.Iam using ANSYS fluent to simulate the process. so,please can anyone help me i
