How to call thermal conductivity into Fluent UDF?
tpatter15tpatter15 Member Posts: 5
I am writing a UDF to be used for solver feedback based on heat flux. As a preliminary step, I am calculating the directional heat flux at the boundaries. In order to do this I need to call the thermal conductivity into the UDF. My simulation setup is laminar, energized narrow channel flow.
I have been using the following macro "K_store = C_K_L(c,t); " with strange results... I have set the thermal conductivity to a constant value of 0.0242 [W/m-K], but plotting the aforementioned UDF variable gives a contour as shown in the below image (essentially 0 [W/m-K] ).
Is there another method to call thermal conductivity into the UDF that will resolve this discrepancy?
  • DrAmineDrAmine GermanyPosts: 7,890Forum Coordinator
    So if you assign your cell memory the C_K_L(c,t) you get wrong values? Are you setting the laminar conductivity as constant in the GUI?
  • tpatter15tpatter15 Posts: 14Member
    Yes, that's correct . I get the contour plot shown above for thermal conductivity, but I have set the thermal conductivity to a constant as shown in the screenshot below...
    We're assuming the UDM is picking up a value. Can you post the code?
    Rob,
    Attached is the UDF code. I try to call conductivity in both the ADJUST and ON_DEMAND portions.
    Any feedback on why the conductivity is not making it into the UDF would be appreciated.
    Which I'm not permitted to open: please post as you would normal text.
    Sorry about that, code pasted in below:
     # include "udf.h"
    /* Note: need to allocate at least as many UDS and UMDs as are in code below... can update to check for this before running to prevent crash? auto-allocate in UDF? */
    /* Note: Current counts: UDM = 20; UDS = 20 (2-3 spares 2021.11.08)*/
    /* Note: for C_T_G use enter this in comand line before solving: "solve/set/expert" > default (press enter to select [no]) x2 > type "yes" in response to "keep temp. mem. from being freed?" */
    /* Note: alternate command? Not working... "solve/set/advanced/retain-temporary-solver-mem" */
    /* Define which variable names for scalars ??? */
    /* Need to rename UDMs with more verbal descriptions ??? */
     enum
    T_ADJ,
    T_STORE,
    q_flux,
    q_flux_manual
    /* The following code is executed at the END OF EVERY ITERATION */
     DEFINE_ADJUST(adjust_gradient, domain)
    Domain *domain;
    Thread *t;
    cell_t c;
    face_t f;
    real T_ADJ;
    real K_ADJ;
    domain=Get_Domain(1);
    /* Loop over all cells and store or calculate various parameters */
      thread_loop_c (t,domain)
       begin_c_loop (c,t)
    T_ADJ = C_T(c,t);
    C_UDSI(c,t,0) = T_ADJ;
    C_UDMI(c,t,0) = C_UDSI(c,t,0);
    K_ADJ = C_K_L(c,t);
    C_UDSI(c,t,1) = K_ADJ;
    C_UDMI(c,t,1) = C_UDSI(c,t,1);
       end_c_loop (c,t)
    /* Loop over all faces and store or calculate various parameters */
    thread_loop_f (t,domain)
       if (THREAD_STORAGE(t,SV_UDS_I(0))!=NULL)
        begin_f_loop (f,t)
    F_UDSI(f,t,0) = F_T(f,t);
    F_UDMI(f,t,0) = F_UDSI(f,t,0);
       end_f_loop (f,t)
    /* The following code is executed on command ONLY */
     DEFINE_ON_DEMAND(store_gradient)
    Domain *domain;
    Thread *t;
    Thread *t0 = NULL;
    cell_t c;
    cell_t c0 = -1;
    face_t f;
    real T_store;
    real K_store;
    real K_const = 0.0242;
    real q_flux_1, q_flux_2, q_flux_3, q_flux_4, q_flux_5;
    real T_grad_1, T_grad_2, T_grad_3, T_grad_4, T_grad_5;
    real T1, T2;
    real y1, y2;
    real q_manual;
    real xc[ND_ND];
    real xf[ND_ND];
       begin_c_loop (c,t)
    T_store = C_T(c,t);
    C_UDSI(c,t,2) = T_store;
    C_UDMI(c,t,2) = C_UDSI(c,t,2);
    C_UDMI(c,t,3) = NV_MAG(C_UDSI_G(c,t,0));
    C_UDMI(c,t,4) = NV_MAG(C_UDSI_G(c,t,2));
    C_UDSI(c,t,5) = K_store;
    C_UDMI(c,t,5) = K_store;
    C_UDSI(c,t,6) = K_const;
    C_UDMI(c,t,6) = K_const;
    /* The following code calculates q", q"_x and q"_y using the C_UDSI_G macro */
    /* Note: requires UDS equations must be set to "off" (so that they do not solve) for this code to be fully accurate */
    T_grad_1 = NV_MAG(C_UDSI_G(c,t,0));
    q_flux_1 = K_const*T_grad_1;
    C_UDSI(c,t,7) = q_flux_1;
    C_UDMI(c,t,7) = q_flux_1;
    T_grad_2 = C_UDSI_G(c,t,0)[0];
    q_flux_2 = K_const*T_grad_2;
    C_UDMI(c,t,8) = q_flux_2;
    T_grad_3 = C_UDSI_G(c,t,0)[1];
    q_flux_3 = K_const*T_grad_3;
    C_UDMI(c,t,9) = q_flux_3;
    /* The following code calculates q"_x and q"_y using the C_T_G macro */
    /* Note: requires "solve/set/expert" command per note at top of UDF */
    T_grad_4 = C_T_G(c,t)[0];
    q_flux_4 = K_const*T_grad_4;
    C_UDMI(c,t,10) = q_flux_4;
    T_grad_5 = C_T_G(c,t)[1];
    q_flux_5 = K_const*T_grad_5;
    C_UDMI(c,t,11) = q_flux_5;
       end_c_loop (c,t)
    /* The following code calculates q"_y using the a manual gradient at the faces only */
    /* Section can be improved to loop through boundary faces only... */
    /* new stuff start */
       begin_f_loop (f,t)
    c0 = F_C0(f,t);
    /* t0 = F_C0_THREAD(f,t); */
    t0 = THREAD_T0(t);
    T1 = C_T(c0, t0);
    C_UDSI(c0,t0,13) = T1;
    C_UDMI(c0,t0,13) = T1;
    C_CENTROID(xc, c0, t0);
    y1 = xc[1];
    C_UDSI(c0,t0,14) = y1;
    C_UDMI(c0,t0,14) = y1;
    T2 = F_T(f,t);
    F_UDSI(f,t,15) = T2;
    F_UDMI(f,t,15) = T2;
    F_CENTROID(xf, f,t);
    y2 = xf[1];
    F_UDSI(f,t,16) = y2;
    F_UDMI(f,t,16) = y2;
    q_manual = K_const*(T1-T2)/(y1-y2);
    F_UDSI(f,t,12) = q_manual;
    F_UDMI(f,t,12) = q_manual;
    C_UDMI(c0,t0,17) = F_UDMI(f,t,12);
       end_f_loop (f,t)
    /* new stuff end*/
    Why are you doing these 3 steps?
    K_ADJ = C_K_L(c,t);
    Try
    C_UDSI(c,t,1) = C_K_L(c,t);
    I wonder if the first step is losing the cell values.
    If you are solving the UDS's so the value you get in the memory won't always correspond to C_K_L so be careful there.
    All,
    I will admit the intermediate steps are not necessary, but should not have impeded data storage. I tried modifying the UDF to store the conductivity directly in a UDS (C_UDSI(c,t,1) = C_K_L(c,t);) but the result was unchanged from the errant contour above.
    Also I confirmed that I am not solving the UDS equation for the UDS assigned to conductivity.
    Any other tips to troubleshoot this issue?
    Tyler
    If you just put the laminar conductivity in Memory and you check the memory: will it show the same value or not. Forget about all other parts in the UDF: just check that part in a couple of lines UDF.
    Using a simple udf which just stores the conductivity in a scalar or memory produces the same results shown above... approximately zero.
    Tyler
    Can you post the lines in the simple UDF?
    Here is the code for the simple conductivity UDF:
     # include "udf.h"
     DEFINE_ADJUST(adjust_data, domain)
    Domain *domain;
    Thread *t;
    cell_t c;
    face_t f;
    real K_ADJ;
       begin_c_loop (c,t)
    K_ADJ = C_K_L(c,t);
    C_UDMI(c,t,1) = C_UDMI(c,t,1);
       end_c_loop (c,t)
     DEFINE_ON_DEMAND(store_data)
    Domain *domain;
    Thread *t;
    cell_t c;
    face_t f;
    real T_store;
    real K_store;
       begin_c_loop (c,t)
    T_store = C_T(c,t);
    C_UDSI(c,t,5) = C_K_L(c,t);
    C_UDMI(c,t,5) = C_K_L(c,t);
       end_c_loop (c,t)
    Note: there was an error in the code above... In the DEFINE_ADJUST portion, "C_UDMI(c,t,1) = C_UDMI(c,t,1);" should be "C_UDMI(c,t,1) = C_K_L(c,t);"
    This update made no difference, still have the conductivity error in my UDF.
    I created a small UDF to verify and I am able to access the thermal conductivity and the value does match the value I am using in Ansys Fluent. In my small UDF I am taking care that the data access should be done on Nodes only (Starting with #if !RP_HOST and ending with #endif).
    Again check everything without any DEFINE_ADJUST in ON_DEMAND.
