Warning about material fit range and simulation bandwidth
MadafaMadafa Member Posts: 1
Dear Ansys Lumerical staff,
I run into a problem where the program prompts a warning that says "material xx uses a fit range that does not fully overlap the simulation bandwidth", as you can see in the image inserted.
However, I did fitting for every material, and the fit range is the same as the simulation bandwidth. So I have no idea about how to get rid of this problem. It didn't happen before, but now all of my previous simulation files have the same warning.
It would be highly appreciated if someone is willing to help me. Thank you very much in advance.
