Workbench Model Opening Issue
MLBCMLBC Member Posts: 1
Hi everyone,
Since I upgraded Ansys From 2019R2 to 2021R1, I can't open the mechanical windows in workbench.
There is no error messages, only a message "starting mechanical...". Workbench is loading until I stop it in the task manager...
I let it run for more than one hour now, and there is still no messages or mechanical window.
Did somebody already faced this issue ?
Thanks !
  • KremellaKremella Posts: 3,106Admin
    Is this the case with any project? Or is it only this specific project file? Are you able to create a new project and launch WB?
    Also, could you please share a screenshot of the issue?
  • MangeshANSYSMangeshANSYS Posts: 35Forum Coordinator
    Hi
    click on windows start button and type "msinfo32.exe" and click "System Information" in results.
    Expand Software Environment and Navigate to Environment variables in the left pane, then click in the right pane of system information, press Ctrl + A to select All and Ctrl+C to copy the listed environment variables
    Paste the contents in a response here
  • MLBCMLBC Posts: 4Member
    ANS_OLD_ATTACH 1 <SYSTEM>
    ANSYS211_DIR C:\Program Files\ANSYS Inc\v211\ANSYS <SYSTEM>
    ANSYS_CLIENT_DISABLE_FNO_PING 1 <SYSTEM>
    ANSYS_SYSDIR winx64 <SYSTEM>
    ANSYSLI_ELASTIC 0 <SYSTEM>
    ANSYSLI_ELASTIC 0
    ANSYSLI_LCP 0 <SYSTEM>
    ANSYSLI_LCP 0
    AWP_LOCALE202 fr
    AWP_LOCALE211 fr
    AWP_ROOT211 C:\Program Files\ANSYS Inc\v211 <SYSTEM>
    BPPDOMAIN_MANAGER_ASM EdrDotNet, Version=7.5.0.36150, Culture=neutral, PublicKeyToken=da1b3922653ea916 <SYSTEM>
    BPPDOMAIN_MANAGER_TYPE EdrDotNet.EdrAppDomainManager <SYSTEM>
    CADOE_LIBDIR202 C:\Program Files\ANSYS Inc\v202\CommonFiles\Language\fr <SYSTEM>
    CADOE_LIBDIR211 C:\Program Files\ANSYS Inc\v211\CommonFiles\Language\fr <SYSTEM>
    LSTC_LICENSE ANSYS <SYSTEM>
    NUMBER_OF_PROCESSORS 8 <SYSTEM>
    P_SCHEMA C:\Program Files\ANSYS Inc\v211\AISOL\CADIntegration\Parasolid\PSchema <SYSTEM>
    Path %SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;%SYSTEMROOT%\System32\OpenSSH\;C:\Program Files (x86)\Common Files\Hitachi ID\;C:\Program Files\Common Files\Hitachi ID\;C:\Program Files\Citrix\System32\;C:\Program Files\Citrix\ICAService\ <SYSTEM>
    Path %USERPROFILE%\AppData\Local\Microsoft\WindowsApps; NT AUTHORITY\SYSTEM
    PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC <SYSTEM>
    PROCESSOR_ARCHITECTURE AMD64 <SYSTEM>
    PROCESSOR_IDENTIFIER Intel64 Family 15 Model 6 Stepping 1, GenuineIntel <SYSTEM>
    PROCESSOR_LEVEL 15 <SYSTEM>
    PROCESSOR_REVISION 0601 <SYSTEM>
    PSModulePath %ProgramFiles%\WindowsPowerShell\Modules;%SystemRoot%\system32\WindowsPowerShell\v1.0\Modules;C:\Program Files\Citrix\Telemetry Service\ <SYSTEM>
    TEMP %SystemRoot%\TEMP <SYSTEM>
    TEMP %USERPROFILE%\AppData\Local\Temp NT AUTHORITY\SYSTEM
    TMP %SystemRoot%\TEMP <SYSTEM>
    TMP %USERPROFILE%\AppData\Local\Temp NT AUTHORITY\SYSTEM
    UATDATA C:\WINDOWS\CCM\UATData\D9F8C395-CAB8-491d-B8AC-179A1FE1BE77 <SYSTEM>
    USERNAME SYSTEM <SYSTEM>
    windir %SystemRoot% <SYSTEM>
    You'll find here the environnement variables.
    Yes this is the case for all projects:
    Workbench is blocked, and do not send any error message.
    Thank you,
    Matthieu
