ANSYS LICENSE MANAGER ERROR
Good day!
I just downloaded Ansys Student, and get the following errors when I run the CFX 2021 R2 Solver. Mainly: "Could not connect to license server: 54896@DESKTOP-C86IEEF." Strangely enough, just yesterday night I ran the solver with exactly the same set up and had no errors. Thank you for helping me.
  This run of the CFX 2021 R2 Solver started at 10:42:23 on 12 Nov 2021
 by user voran on DESKTOP-C86IEEF (intel_xeon64.sse2_winnt) using the
 command:
 "C:\Program Files\ANSYS Inc\ANSYS Student\v212\CFX\bin\perllib\cfx5solve.pl"
  -batch -ccl runInput.ccl -fullname CFX_009
 2021 R2
 Point Releases and Patches installed:
 Academic Student 2021 R2
 Aqwa 2021 R2
 EnSight 2021 R2
 FENSAP-ICE 2021 R2
 Setting up CFX Solver run ...
 END
 |            ANSYS(R) CFX(R) Solver            |
 | 2021 R2                              |
 | Build 21.2 2021-05-14T23:10:23.832818               |
 | Sat May 15 01:34:33 GMTDT 2021                   |
 |            Executable Attributes            |
 |      single-64bit-int32-archfort-optimised-std-lcomp     |
 | (C) 1996-2021 ANSYS, Inc.                     |
 | All rights reserved. Unauthorized use, distribution or duplication |
 | is prohibited. This product is subject to U.S. laws governing   |
 | export and re-export. For full Legal Notice, see documentation.  |
 |         Job Information at Start of Run          |
 Run mode:    serial run
 Host computer: DESKTOP-C86IEEF (PID:4396)
 Job started:  Fri Nov 12 10:42:27 2021
 |            License Information             |
 License Cap:  ANSYS CFD Solver
Could not connect to license server: 54896@DESKTOP-C86IEEF. Connection timed out while connecting to the server.
 License ID:   License checkout failed (CFD SOLVER).
 | ERROR #001100247 has occurred in subroutine .           |
 | Message:                              |
 | The solver is unable to continue because of licensing problems.  |
 | A license for the following capability level could not be checked |
 | out:                                |
 | ANSYS CFD Solver                          |
 | Please carefully examine the error message output above and check |
 | that:                               |
 | 1) The license server is specified correctly and is running.    |
 | 2) An appropriate license is available for checking out.      |
 | These problems can be checked using the ANSYS Client ANSLIC_ADMIN |
 | utility. For further troubleshooting information please consult  |
 | ANSYS, Inc. Licensing Guide.                    |
 |        An error has occurred in cfx5solve:         |
 | The ANSYS CFX solver exited with return code 1.  No results file |
 | has been created.                         |
End of solution stage.
 | For CFX runs launched from Workbench, the final locations of    |
 | directories and files generated may differ from those shown.    |
This run of the ANSYS CFX Solver has finished.
  • Geo KarnosGeo Karnos Posts: 504Ansys Employee
    edited November 15 Accepted Answer
    Try running with your Firewall temporarily shut down to see if that allows you to run.
    If that does not work, what is the output from running the following in a DOS Command Prompt:
    ping DESKTOP-C86IEEF
    Also, under: %TEMP%\.ansys, you should see licdebug files. check those for any error messages.
    Please post the error messages as we are not permitted to open files.
