Udf for species concentration (interfacial area udf)
majammajam Member Posts: 3
I am writing 3 different udfs for calculating the concentration of 3 different species of mine. I also have a mass transfer coefficient in another UDF.
I need to use that mass transfer coefficient in one of the concentration UDFs. part of udf is as follows:
OXN = C_YI(c,t,2) * C_R(c,t)+kl*a*(0.08- C_YI(c,t,2) * C_R(c,t)); /*O2 concentration*
I stored kl in a UDM and will replace it in the above line but for a (interfacial area)
So here ''a'' is the interfacial area between gas and liquid. So in case I use a single bubble size in my model I can write the following code for the interfacial area and then store in another UDM and use it in the line mentioned above.
UDF for specifying interfacial area
#include "udf.h"
real area_intf;
DEFINE_EXCHANGE_PROPERTY(custom_ia,c,t,i,j)
/* i -- liquid-phase; j -- vapor-phase */
Thread **pt = THREAD_SUB_THREADS(t);
real diam = C_PHASE_DIAMETER(c, pt[j]);
real vof_i = C_VOF(c,pt[i]);
real vof_j = C_VOF(c,pt[j]);
area_intf = 6.*vof_j/diam;
C_UDMI(c,t,1)=area_intf;
return area_intf;
1- I wanted to make sure if this is correct?, since I get 0 for data stored in C_UDMI(c,t,1).
2-Also I wanted to see if anyone knows how do I define interfacial area when I am using '''''' interfacial area concentration model'''''' with a range of bubbles from 2mm to 1 cm?
3-Is there any specific variable in fluent that I can directly use (similar to density, viscosity ,...)? Or do I need to find the interfacial area for different bubble categories? (sth similar to PBM) and
3-1- in this case, what is the bubble size macro for the interfacial area concentration model?
Many thanks,
  • sdebsdeb Posts: 327Forum Coordinator
    Are you using this to provide interfacial area for Eulerian multiphase boiling Model? Also print out the vof values in the UDF to diagnose this.
    SD
