Boundary condition ansys fluent
tumitumi Member Posts: 22
What boundary condition and approach I should take?
I have 4 pipes coming from sea (source tank) and these 4 pipes are taking water from sea with help of water pump(p1, p2, p3, p4) and put it to tank, which is in vertical height of say 6 meter from sea. I want know
Effective combined pump flow rate for this combination of piping system & parallel pump
Also flow rate at tank individually by pipes also
  • RobRob UKPosts: 11,770Forum Coordinator
    What information have you got?
  • tumitumi Posts: 105Member
    Hello Rob
    Thanks for commenting, I don't have yet now input for this project.
    But I would like to explore and know, how many ways are there to approach it.
    Like one time may be I know inlet velocity or mass flow rate
    On other situation, I don't know inlet velocity or mass flow rate.
    Just trying to explore different scenerio in internal pipe flow cases.
    You will know something, that may be the flow rate OUT of the system, no reason not to use a suction (negative velocity) boundary. If the flow is constant density use velocity bc, it's more stable and only takes a minute or so to work out.
