Mesh error Forte
jerom26jerom26 Member Posts: 5
Hello everyone,
During my simulation there seems to be a mesh error.
It occurs when it reaches 17 CA in the simulation. I guess that it is due to the valve activation threshold.
When the valve lift curve reaches 0,1 mm the error occurs. The valve activation threshold is set to 0,1 mm.
The error looks like this:
Does anyone know what might've caused this error?
Thanks a lot in advance!
  • jerom26jerom26 Posts: 15Member
    Accepted Answer
    I wasn't abled to use enough cores due to my license.
    I set the activation threshold for the valves to 0,3 cm and 3 layers.
    Now it didn't give an MPI-deadlock, but it isn't as accurate as it should be.
    Using more cores would solve the problem.
