Could someone explain why the mass flow monitors are showing unrealistic values?
avinashnairavinashnair Member Posts: 1
I'm simulating an airflow into the enclosure through the inlets as shown. based on the hand calculations for a velocity of 5m/s, the mass flow rate should be around 0.375 kg/s . But I'm getting unrealistic values at the inlet as well the exit when I'm using monitors for flow rates. i have attached some screen shots of the geometry as well as the monitor plot.
Best Answers
    Accepted Answer
    Staff are not permitted to open attachments so please repost. Check the domain extents too: you may have inadvertently scaled the domain.
    Accepted Answer
    :) Don't worry, I've seen a few of those over the years. I think the best was the silo with natural convection and 1400m/s gas velocities: the silo was 9km high......
