Having trouble saving pictures of an animation to a video file.
nicko627nicko627 Member Posts: 1
I have saved a series of images to the .tiff file format. I can open the respective cxa file in fluent and play the animation of these files, but when I try to save this animation to a video, I get the error below. I am using Fluent 2021 R1. How can I get around this? I have not been able to find a program to work around this issue.
  • DrAmineDrAmine GermanyPosts: 7,890Forum Coordinator
    Accepted Answer
    Perhaps you load the cxa file in empty Fluent session without reading any Case file. Check what Karthik is recommending and if still having issues as workaround use Ansys EnVe to create the animation or just rely on ffmpeg
