Question of planar solar cell exampe(from Lumerical Support)
Hi. I am studying the lumerical simulation by following the planar solar cell example provided by lumerical.
As a result of following the picture above, step.1 (FDTD) and step.2 (HEAT) worked well, and the problem is step.3 (CHARGE).
After RUN of the CHARGE simulation file, I tried to run the script provided in the example.
But the following message appears, and it does not work.
And the page of the script shown like this.
I can't find what is the problem.
Please help me.
    Accepted Answer
    Thank you to bring this issue to our attention. The article mentions voltage sweep:
    But the CHARGE file used fixed zero voltage. You can edit the "emitter" or the "base" to have voltage sweep. From the script, modifying "base" is better:
    Then it should work. I have tested and verified. Please try to modify and see if it works.
