Ansys ACP Error: Elements have several common nodes but no common edge. Check mesh!
Hi
I am modeling a composite structure, structure is defined with surfaces (2D). I have done this procedure before. First I model and apply loads and then use ACP to model the composite laminate. Now my problem is that in ACP Pre when I want to define the oriented element set, I get this error:
While before going in ACP Pre I solved the model in Mechanical. Can anyone help me in finding the elements and nodes which are causing the problem. The structure consists of 800 parts and I removed some parts and then added the other parts, it works properly when I model each section of the structure but just as I mesh whole of the structure I get this error.
Thanks in advance
