Mass Flow Inlet Boundary Conditions
alperniaalpernia Member Posts: 2
I'm simulating an air flow hitting water in a tank. I’m using multiphase model VOF with air and water as the phases… and both incompressibles. I have used “Mass flow inlet” boundary condition at the inlet. Everything seems right with the results (flux report, residuals, contour plots, etc.). Nevertheless, I have read in the User Manual this:
Limitations and Special Considerations: “Mass flow inlet boundary conditions cannot be applied to any of the multiphase models if all phases are incompressible”
Does this mean that I can not use it?
Thank you in advance for your answer.
Alpha
