floating point exception
AbdelrahmanOmarAbdelrahmanOmar Member Posts: 12
How can I solve this problem ?!
Error: floating point exception
Error Object: #f
SC Fluent encountered fatal error. Saving case/data file....Writing "| gzip -2cf > G:\System Coupling\21 11 2021 System coupling + Transient\Final_files\dp0\FFF\Fluent\FFF.1-2-00003.cas.gz"...
Writing temporary file C:\\Users\\ABDELR~1\\AppData\\Local\\Temp\\flntgz-168884 ...
  32000 hexahedral cells, zone 2, binary.
  32000 cell partition ids, zone 2, 4 partitions, binary.
  92800 quadrilateral interior faces, zone 1, binary.
  4800 quadrilateral wall faces, zone 5, binary.
  1600 quadrilateral pressure-outlet faces, zone 6, binary.
  35301 nodes, binary.
  35301 node flags, binary.
Done.
Writing "| gzip -2cf > G:\System Coupling\21 11 2021 System coupling + Transient\Final_files\dp0\FFF\Fluent\FFF.1-2-00003.dat.gz"...
Writing temporary file C:\\Users\\ABDELR~1\\AppData\\Local\\Temp\\flntgz-168885 ...
Done.
Done.
Deleting Client...done
Shutting down Server...done
Writing "| gzip -2cf > SolutionMonitor.gz"...
Writing temporary file C:\\Users\\ABDELR~1\\AppData\\Local\\Temp\\flntgz-168886 ...
Done.
Writing data to G:\\System Coupling\\21 11 2021 System coupling + Transient\\Final_files\\dp0\\FFF\\Fluent\\FFF.1.ip ...
x-coord
y-coord
z-coord
pressure
x-velocity
y-velocity
z-velocity
k
omega
hyb_init-0
hyb_init-1
mp-1
mp-2
Done.
  • DrAmineDrAmine GermanyPosts: 7,890Forum Coordinator
    Looks like System coupling analysis: so quite hard for us to suggest anything apart from the classic suggestions: check your mesh deformation, time step, convergence, .... Try to simplify the issue and run first static run without any coupling and check if it is converging.
