How to turn a line into a thin 2D area?
jgrani6jgrani6 Member Posts: 2
Hello, I am trying to model a thin walled pressure vessel using axisymmetric option for solid element. I have a set of lines which draw the outer edge. I've done it with shell elements easily, I now want to model it using Solid 182 elements using axisymmetric option. However, I need to mesh area for plane elements. How do I add thickness to my lines so that instead of lines, I have 2d areas that still draw the outer edge?
  • jgrani6jgrani6 Posts: 3Member
    This is in Mechanical APDL
  • wrbulatwrbulat Posts: 62Ansys Employee
    Please try this test case I created then see if you can apply this strategy to your model:
    fini
    /cle
    /vie,1,1,1,1
    /pnu,kp,1
    C*** PARAMETERS
    r=0.5 ! END RADIUS
    l=1 ! LENGTH OF STRAIGHT SECTION BETWEEN SPHERICAL ENDS
    t=0.10 ! PRESSURE VESSEL WALL THICKNESS
    C*** PRESSURE VESSEL EXTERNAL SURFACE
    /prep7
    wpcs,-1,0
    wpof,,-l/2
    cswp,11,1
    k,1,r,-90
    k,2,r,0
    l,1,2
    wpof,,l
    cswp,12,1
    k,3,r
    k,4,r,90
    l,3,4
    csys
    l,2,3
    lplo
    /wait,2
    C*** CREATE AREA REPRESENTING PRESSURE VESSEL WALL CROSS SECTION
    allsel
    numc,line
    csys
    *get,ymin,kp,,mnloc,y
    *get,ymax,kp,,mxloc,y
    kgen,2,kp(0,0,ymin),,,0,0,t,500
    l,kp(0,0,ymin),kp(0,0,ymin)+500
    *get,lmax,line,,num,max
    adrag,all,,,,,,lmax
    aoff,all,-t,1000
    lsel,s,loc,z
    asel,none
    l,kp(0,ymin,0),kp(0,ymin,0)+1000
    l,kp(0,ymax,0),kp(0,ymax,0)+1000
    al,all
    cm,keep_a,area
    cm,keep_l,line
    alls
    cmse,u,keep_a
    cmse,u,keep_l
    adel,all,,,1
    ldel,all,,,1
    alls
    aplo
    Best,
    Bill
