ANSYS APDL Error
KaKashaKaKasha Member Posts: 6
Dear ANSYS employees
I'm using ansys apdl to simulate a slab failure, I have all the parameters correct, but I don't know what is this error and how to solve it.
I have two line (solid ) and different from solid 65 as a support, and a box to apply the force.
Does these errors related to them or what?
I really appreciate your help.
Regards
  • cscs Posts: 39Ansys Employee
    Error 1: "Viewing directions is parallel ...." I think you might be doing a section view (/CPLANE,1 command). This error seems to say that your view direction (/VIEW command) is parallel to the working plane cut which means the cut section cannot be displayed. You may want to change to /CPLANE,0 so the section cut is normal to the view direction.
    Error 2: " Volume 1 is meshed and cannot be...." This usually happens if you try to remesh an already meshed volume or if you try to modify/delete elements of a meshed volume.
