How to see the Author of a file/change Log?
Hallo
I want to see who has worked on a Ansys Workbench fluent file. Is there some option, how to see who has changed things? Like a change Log. A username or an IP adress of the guys who have worked on a file would be good.
Thanks in advance
  • RobRob UKPosts: 11,770Forum Coordinator
    Accepted Answer
    There are .trn files produced when Fluent is launched. Assuming they're retained in the FLU folder the first 5-10 lines or so will report the hardware used and where the file was opened from (folder path).
