Why is the inflation being compressed on one side of the tube?
Karl19Karl19 Member Posts: 1
 Highlighted in red - The inflation layer at those areas is compressed significantly when applying the MultiZone method. Does anyone have any idea how to go about it? Should I use another method for hex mesh instead of MultiZone? Also are there any suggestions on how I can further improve the t ball valve mesh? Thanks.
  • KremellaKremella Posts: 3,123Admin
    Are you using the Global Inflation settings to specify your Boundary layers? Which method are you using? Did you try changing the method?
    Also, do you have any contact between the regions with Hex and Tet meshes?
