How the scale factor under geometry tab works?
BalochBaloch Member Posts: 15
I am want to scale a structure with 1:2 which means I want to double the size of the structure I have. Under the geometry tab which I use scaling factor of 2 it will increase the volume and mass of my structure almost by 8 time. Any one have idea how this scaling factor works? Mass of my original structure is 11000kg and volume is 4.581m^2 after using scale factor of 2 it will change the mass and volume to 81687kg and 35.843 m^3 respectively.
Best regards
