No Connection from Transient Structural Solution to Fluent Results in Ansys 2021 R1.
yhammiyhammi Member Posts: 1
When running 2-Way FSI the Hyperelastic Flap example, the analysis successfully completed but Ansys Workbench 2021 R1 cannot create a connection from the Solution cell of Transient Structural to the Results cell of Fluid Flow (Fluent). When trying to draw the connector, Ansys Workbench is showing a forbidden sign. It is not possible in both Windows and Linux platforms. However, it is possible to do it in Ansys 2019 and 2020 R2 with the same example. If the project from Ansys 2020 R2 that has the connection, and then opened in Ansys 2021 R1, double clicking the Results cell of Fluid Flow (Fluent) leads to the following message:
"CFD-Post does not support reading Transient Mechanical 2021 R1 or later results files. Mechanical results will not be loaded. Please remove the connection from Mechanical Solution 1 to CFD-Post Results."
Is there any update that can solve this issue? Thanks.
