License page does not show at Setup
F. Semih YF. Semih Y NetherlandsMember
I installed Ansys 19  but selected the wrong amount of license machines. Instead of pressing 1-server I selected 3-server (it was selected on default). After installation the software would not start because of a licensing issue.
I installed the license manager but could not figure out how to change this mistake. So instead I uninstalled. When reinstalling now, the page in the image does never show in the setup wizard. What now?
    edited November 2018
    Hi F. Semih Y ,
    That setting would write out the 'ansyslmd.ini' file under <install_dir>ANSYS IncShared FilesLicensing
    You can always change this without deleting this file and reinstalling products by using Client ANSLIC_ADMIN Utility v1xx (with 'run as administrator') -> Specify the License Server Machine
    Don't install the ANSYS License Manager on your local machine unless you receive a license file from ANSYS Account Manager that is generated for your machine.
    Thank you,
    Win
