Error analysis when simulating some sturctures
EunJooEunJoo Member Posts: 8
Hello.
I have to simulate optical cavities with a dipole source. When I set LC attribution for the bottom, a problem showed up.
I got this message below.
I referred to this problem (https://forum.ansys.com/discussion/25553/fdtd-error-exit-code-0xc0000005) but I can't handle this. I am able to run 'mwp.fsp' from the Applications Gallery (Apps) which is proposed in the upper forum. I guess memory requirement could be the problem so I check it. Memory required to run my simulation is 6.7 GB, and an available memory on my computer is 17.8 GB. I wonder in this case the memory still be causation for simulation error? How to fix or avoid this matter?
