Rotor vibration/deformation due to grid voltage change( frequency change, short circuit current)
Ahmad2529Ahmad2529 Member Posts: 4
Good Day!
I need to see the vibrations induced in the rotor because of short circuit current and changing grid parameters, I am not able to select the correct platform. I was doing the simulation using harmonics module, but it does not allow using frequency or short circuit current for checking the vibration studies.
Can someone please guide me in this regard.
Let me know if you have any questions.
