Simulating racetrack resonator add-drop filter with MODE 2.5D - Getting incorrect FSR
cfphotoncfphoton Member Posts: 1
I am attempting to simulate a racetrack resonator in an add-drop filter configuration (so with two coupled waveguides.) Full 3D FDTD is too demanding, so I have been using the 2.5D varFDTD solver in MODE.
The device parameters are the following: SiN (sampled index file) waveguide, 1um wide by 800nm tall, embedded in SiO2 (index = 1.46). The bending radius of the round sections of the couplers and resonator is 20um. The straight sections are all
12um. The coupling gap is 400nm (but this could be anywhere from 300 to 800nm). I have placed four transmission monitors at the input, through, add, and drop ports, and I am exciting the input waveguide with a mode source set to fundamental mode. I would like to see the transmission from approximately 1540nm to 1560nm. The varFDTD slab mode position is set to one of the racetrack straight segments.
The simulation runs fine, but the Free Spectral Range (FSR) is way off. In experiment, I have consistently observed an FSR of approximately 3nm for this device, but the simulation consistently gives me something approximately twice that.
In the past I have simulated similar (albeit smaller) devices with Silicon waveguides and have managed to replicate experimental results. The exact simulation parameters used there (such as meshing, sim time, varFDTD effective index settings etc) are not giving correct results for the SiN system.
I am aware that broadband simulations in 2.5D can be an issue. I have the varFDTD object set to a broadband simulation, but I can't rule out that something is breaking there because the mode source is single wavelength.
Please let me know if there are any other settings that might be an issue, I am running out of ideas to try and replicate these results.
I have attached some screen shots and am happy to upload an .lms file. Thank you very much for any help.
P.S. I have made sure that the sim time is sufficiently long for the fields to decay, and I have tried numerous different mesh settings up to auto non-uniform accuracy 5.
One strange thing I have noticed is that the mode source calculates the effective index of the mode as approx 1.78, but the varFDTD solver calculates it (when choosing 'user select') as 1.86. I am not sure what causes this discrepancy, and I believe the mode source is correct.
  • gsungsun Posts: 1,692Ansys Employee
    This is an interesting question.
    varFDTD is a variation to the original 3D FDTD. It can perform the best when the decomposed 1D modes well match 2D modes: it decomposes the original 2D modes into 1D z lab mode in "effective index" tab, and the mode source (in your case it seems 1D y equivalent waveguide). Its physics can be found here MODE - 2.5D varFDTD solver introduction
    and it is know that FSR is different due to the decomposition: https://support.lumerical.com/hc/en-us/articles/360042800293-Ring-resonator-getting-started-Design-and-initial-simulation
    It is used for quick design but we recommend to use 3D FDTD for final verification.
    In addition, please make sure that the SiN material data in the material database represents your actual device material. Otherwise your design will deviate the real device. As you can seem the material data in the material database has large difference between Phillip and Kischkat .
    As for the discrepancy of neff, it is normal because of the waveguide is "different" (check the cladding effective index). However, when you use "user select", please make sure it is the same polarization as in the "Effective index". This is critical to get correct result.
    One more thing: You do not need to use single wavelength source. I would suggest to use broadband, as you mentioned from 1.54 to 1.56um would be better, since numerical dispersion will shift the actual resonance. (This is a different topic).
  • cfphotoncfphoton Posts: 6Member
    Hi gsun,
    Thanks for your reply! I think what you said about the material data may be crucial. In particular I recreated the waveguide geometry cross section in another file (using the same material files) and calculated the group index for the fundamental mode. It is very close to 2.075 across the whole wavelength range.
    I then did a basic calculation. FSR = c/(L * ng) where c is speed of light, L is the length of the resonator (4*12um+2pi*20um=173.7um).
    This gives FSR = 0.83 THz, which is exactly what I observe in simulation, which disagrees with experiment. I think this is a good indication that 2.5D is creating a 2D model that accurately represents the group index that Lumerical has calculated, but this group index does not correspond well to experiment. The only reason I can think of that would cause this is that the material file is inadequate.
    I am attempting the same calculation with the Kischkat material file now. I will update here if it ends up replicating the measurement well. It is very strange that there is so much disagreement between material files for SiN... I wonder why that is.
    Comparing simulation with experiment can be challenge in some cases, especially if you do not know exactly the material the device used. Please refer this post:
    Ansys Insight: Why my simulation result is different from published paper or experiment?
    Hi gsun, thank you for that link. I will go through it.
    In this case, I performed the experiment so I have very detailed knowledge of the device in question. Using the Kischkat material file did not produce the correct results. So far I have 3 different FSRs: 0.83 THz from our sampled material file, 0.65 THz from Kischkat, and 0.4 THz from experimental measurement.
    I believe the problem is in the calculation of the group index. I attempted to calculate the group index with "detailed dispersion calculation" on but saw no change. I am now using the multi-coefficient model to get a better fit to the sampled data.
    I will keep trying this as well as things in the list you provided.
    I would suggest to have a measured refractive index from your device, as the material can have quite different property. The group index is correct from FDE but it depends on the material index (and waveguide).
    Hi gsun,
    The material file I have is a measured/sampled refractive index file from the foundry that performed the fabrication. It should be reliable. Selecting "detailed dispersion" calculation and fine tuning the multi-coefficient model made no significant changes to the calculated group index.
    I am currently performing some 3D FDTD simulations of the ADF to see how the FSR comes out. The rings themselves are very large though (20um bending radius + 12um straight sections) so I may not be able to simulate the system beyond a coarse mesh (mesh accuracy 2, possibly 3 at best...). If it replicates the 2.5D result we can probably assume that the issue is either the index file or the device itself not being to spec (which seems unlikely).
    If it does not replicate the 2.5D, there are a few possibilities:
    1. Any difference in meshing may have caused an issue.
    2. The source's frequency dependent profile option in FDTD that is not available in MODE made a difference.
    3. The effective 2D index calculated by MODE is not accurately representing the 3D geometry for some reason.
    If the simulation fails to finish in a reasonable time, I will simulate a smaller ring. It will not agree with our experiment, but we can at least test if 3D agrees with 2.5D for this material file.
    I do not expect that 3D agrees with 2.5D, as explained previously, especially the FSR. This is because the waveguide is simplified, and since the neff is different from FDE (2D cross section) from two 1D waveguide, the resonance can be different. Smaller FSP means strong resonance, so you will need
    1: significantly reduce autoshutoff min ,
    2: increase simulation time.
    You can take advantage of "check point": set long enough simulation, change autoshutoff min from one simulation to resume with smaller autoshutoff min. Please refer
    https://support.lumerical.com/hc/en-us/articles/360036896474-resume-Script-command
    https://support.lumerical.com/hc/en-us/articles/360034382534-FDTD-solver-Simulation-Object
    Hi gsun,
    Sorry if I missed that, but that is very surprising to hear... even the 2.5D whitepaper ( https://www.lumerical.com/learn/whitepapers/lumericals-2-5d-fdtd-propagation-method/) uses an add-drop config ring resonator as its main example.
    They even explicitly say "In particular, the key quantities we typically extract from such a simulation, the bandwidth and free spectral range (FSR), are very accurately calculated with the varFDTD method, which is not the case with the standard 2D FDTD approach." indicating that varFDTD can accurately recreate 3D results for the FSR (albeit shifted, which is fine).
    I do not see how my simulation is any different than this example, with the exception of the material and straight sections of the ring. In fact, I have been able to replicate experiment just fine with 2.5D previously in silicon (not silicon nitride) devices.
    Thank you for the information on using a checkpoint, that could be very usful.
    Whether varFDTD can accurately get the result the same as 3D FDTD pr not strongly depends on the device. Please refer the reference papers listed in the website. In addition, please refer the exam[le O sent previously. Specifically for this result:
    The white paper indicates varFDTD is much better than 2D FDTD, not 3D FDTD! Please read the text again.
    varFDTD is a quick yet accurate method. However it has limitations and its accuracy needs to be VERIFIED with 3D FDTD, with sufficient long simulation time to let the time signal with high Q resonance completely decay.
    I think I have said enough about the difference. between varFDTD and 3D FDTD. However the difference between simulation and experiment can be originated from many different causes. Please read the post previously provided.
    Hi gsun,
    Thanks for responding again. I did not say that varFDTD is better than 3D at any point. I said "varFDTD can accurately recreate 3D results for the FSR" which is the claim the white paper is making about that particular simulation. I believe I have a good understanding of the limitations of varFDTD compared to full 3D FDTD.
    I will look at some of the papers referenced on the website.
    ok. the statement "varFDTD can accurately recreate 3D results for the FSR" is without problem. However extending its meaning to 3D FDTD might be problematic. 3D results for the FSR means it counts for the 3rd dimension. But it can be different from 3D FDTD. That is what I understand. I personally do not expect to have the same FSR from varFDTD as the 3D FDTD.
    When the physical device is fixed, from this
    The resonant wavelength is different between varFDTD and 3D FDTD, I do not think the FSR is the same, except a coincidence that lambda^2/ng is fixed for the two simulations.
