Element erosion due to high temperature
thermal_joethermal_joe Member Posts: 1
I'm facing some problems to kill elements above a temperature treshold.
I'm using the following loop to implement a gaussian heat flux, which is alternatin in a circle:
The heat flux application is easy, but the element selection due to high temperature is not working at all.
*do.....%
*if......element selection and ekill loop
 cmsel,s,erode,elem
 esel,r,bfe,temp,tmin,tmax,tol
 cm,melting,elem
 allsel,all
 outres,all,all
 ekill,melting
*else
*endif
*do....%loadloop
moving heat flux
allsel,all
outres,all,all
Time,.......%
*enddo
*enddo
I guess the element temperature due to heat isn't available for processing in the solution and I have to implement
something like:
/post
etable,temperature,temp
esel,r,bfe,tmin,tmax,tol
cm,melting,elem
/solu
/anytype,restart
to acess the element temperature in the loop to kill the lements.
I'm not shure how to implement it rigth and where I have to place the commands.
Maybe someone has a clue to solve this.
With best regards
Joe
