Delete unneded files in APDL
BassaSelim3BassaSelim3 Member Posts: 10
HI,
Is there an APDL command which does the same as "delete unneded files" in the analysis settings?
thanks to everyone
Bassa Selim
  • akhemkaakhemka Posts: 1,010Forum Coordinator
    Hi @BassaSelim3 ,
    When the Delete Unneeded Files property is set to Yes (default), the application automatically executes the Mechanical APDL command /FCLEAN. This command deletes all of the unneeded distributed files from the scratch directory when performing a distributed solution. This action eliminates the need to download potentially large distributed files, and as a result, completes your solution faster.
    Ashish Khemka
