Generating Mesh with cells of same area or volume
Dear all,
here attached the mesh that I am creating. Among the different methods and settings that I can adopt, is there a way to set the same area or volume for all cells of the mesh? Since, as I see, if I want to set the sizing, I can do only for the edges.
Thanks in advance for your time.
Best regards,
Christian
  • RobRob UKPosts: 12,322Forum Coordinator
    Please can you repost the image as staff are not permitted to open attachments. If you're using Workbench Meshing you can set volume sizing but depending on the geometry you may not be able to set a uniform cell size.
