should I use real gas or ideal gas for the following simulation?
mario26mario26 Member Posts: 1
edited January 15 in Fluids
should I use real gas or ideal gas for the following simulation? Air flows in, it's an open system, and one wall is heated.
1) If I am to use a real model for the air, which model should I use? Redlich-Kwong ?
2) Where do I enter the outlet pressure at gauge pressure in the outlet area?
3) I have defined the following speed for named expressions: (Re*DynamicViscosity)/(Density*d)
does the calculator for DynamicViscosity and Density take the correct values at the input temperature of 298 K?
I hope you can help me.
Many Thanks
  • RobRob UKPosts: 12,322Forum Coordinator
    Staff are not permitted to open attachments so please repost. The choice comes down to what you're modelling, what the conditions are and whether you need a real gas over ideal gas over constant density.
