two-phase co2 simulation in cfx
Hello
I am working on two-phase co2. In my study, Co2 as a supercritical enters into the vortex tube and there should be different phases. One in vapor co2 and other is liquid co2. In my RGP table, I generated two table, one for vapor and another for liquid. i know that there should be some liquid drop in the domain.
According to the following link: I should choose vapor and liquid materials, as well as a homogeneous binary mixture to define saturation properties. (step 2)
!EDIT: Removed LINK
So, when I choose for example co2 vapor, co2 liquid and co2mix (homogeneous binary mixture), I define three fluids. What should I do?
    edited November 2018
    The binary mixture is not required as phase. It is just required to calculate saturation properties. Define only two phases.
  • abbasabbas Member
    Thanks for your help.
    So, I should add CO2 liquid and CO2 vapor into the FLUID definition. So, how the saturate properties will be calculated?
    Best regards
    Abbas
    They will be calculated via the homogeneous binary mixture you created.
  • abbasabbas Member
    Thanks for your help. Therefore, I shouldn't need to add homogeneous binary mixture in the fluid definition and the solver find the homogeneous binary mixture in the materials section? And I don't need to define it anywhere else?
    Best regards
    Abbas
    No you do not need it in the domain definition. You Need just to create it as explained int axial turbine stage tutorial.
  • zhangguojie2015zhangguojie2015 ChinaMember
    Dear, sir, could you help me do a tutorial about the CO2 non-equilibrium? especially about the material defined.
    Hello
    !EDIT: Removed LINK
    could you help me do a tutorial about the CO2 non-equilibrium? especially about the material defined. Thank you !
    Please create a new thread for your question. Check at first the axial turbine stage tutorial.
