My Ansys Workbench 19.2 opens but doesn't open
Hello, when I open my Ansys Workbench it doesn't let me access it. I can see the app is open in my windows taskbar but it doesn't let me to actually open it. I already tried rebooting my pc, but it didn't work.
Could you please provide me with help?
  • tsiriakstsiriaks 3240 El Camino Real #290, Irvine, CA 92602Posts: 3,071Forum Coordinator
    edited November 2018
    Hi josedjad ,
    Try this,
    close all ANSYS related applications
    open CMD Prompt, then issue the following command (copy and paste the entire line)
    move %appdata%\ansys\v192 %appdata%\ansys\v192.back
    Does this help ?
    Thank you,
    Win
  • cseavs42cseavs42 Posts: 1Member
    edited October 2019
    I had this same issue.  Using this solution worked for me.  Thanks for the help!
    edited October 2019
    Welcome, thank you for letting us know.
  • essbrenntessbrennt Posts: 1Member
    edited May 2020
    Thank you so much! Also worked for the newer versions. ex. just change v192 to v194.
  • anu575dixanu575dix Posts: 5Member
    edited May 2020
    Hi tsiriaks,
    I am using ANSYS workbench 19 R2. I can see the app is open in my windows taskbar but it doesn't let me to actually open it.
    I tried the method you suggested above but that didn't work. Could you please advice how can I solve this issue?
    Thanks.
    Anupam
  • oswaldooswaldo Posts: 1Member
    Hi tsiriaks ,
    Thank you so much, you saved my life. It's really interesting, I had the same problem in two different computers, the last one is a yoga 7 series pro 2021, which supposed to be a 'best'.
    Anyways, from your line I had to adjust the version number that is the last one student version in 2021 (you can verify your version going into pc/c:/program files/Ansys Inc/Ansys student. Probably, this will help for future versions.
    move %appdata%\ansys\v212 %appdata%\ansys\v212.back
    Oswaldo
