ANSYS 19.1 fatal error
When I try to open workbench I get a fatal error "unhandled exception caught"
Tried cleaning up registry and changing the name. Didn't Work.
Hi vadim11,
Could you re-post the screenshot ?
I can't see it.
Win
Hi vadim11,
I can't access this link.
Can you download the screenshot out of it and re-upload it on here ?
Win
Open a Command Prompt (DOS) "as administrator" and issue the following commands
regsvr32.exe ole32.dll
regsvr32.exe atl.dll
regsvr32.exe oleaut32.dll
regsvr32.exe scrrun.dll
regsvr32.exe jscript.dll
regsvr32.exe vbscript.dll
Does this make any differences ?
If that doesn't help, check if you have environment variables ANSYS191_DIR and AWP_ROOT191 set.
Did this v191 work before or this is the first time you install ANSYS on this machine ?
Check your installation directory (default is C:\Program Files\ANSYS Inc) and see if you have install.err file. If so, please post its content here.
Win
the command prompt commands worked.
this was the 1st time I've tried installing it on this machine.
Thank you for the help
That's great !
Thank you for the update vadim11
Win
hello @tsiriaks i have same problem in ansys installation process, but in my case i have install.err file, what should i do with it ?
