"Divergence detected for field Carbondioxide: iterations cancelled by Expert System"
I am doing a mold filling of a chemical reaction flow, but the error "Divergence detected for field Carbondioxide: iterations cancelled by Expert System " occured.
How can solve the divergence problem? I tried to generate a fine mesh of the model, but it was not working.
Many thanks.
  • uxsarahuxsarah Member
    edited November 2018
    The fllowing is a part of the listFile. Can someone please give me some advices, many thanks.
     *     VOF     *
     Running vof for T within [ 0.000E+00 , 2.000E+02 ]
      with dT-ini = 1.000E-01,
           dT-min = 1.000E-02, dT-max = 2.500E-01,
      with up to 2000 successful steps,
      ===> Starting VOF
             at T-ini = 0.000E+00
          Initial volume     =  1.4103619E-04 / 4.1392274E-02
     Preprocessors
     Convergence assumed : Rel. var. LT  1.00000E-04
     F.E.M. Task
     Global divergence has occured. Diverg =  0.2000000E+04
        VOF Step #1                                 |   Progress bar(s)  |
          Time               =  0.0000000E+00       |>                   |
          Volume of fluid    =  1.4103619E-04       |>                   |
          Volume filled (%)  =  3.4073070E-01       |>                   |
          Step status : KO
              Solver divergence occured.
             New time step      =  5.0000000E-02
     Preprocessors
     F.E.M. Task
    Divergence detected for field Urethane: iterations cancelled by Expert System
          Step status : KO
             New time step      =  2.5000000E-02
    Modify the convergence test =2.00000E-3
    Modify the divergence test = 2.00000E+4
    Modify the convergence test for species = 5.000000E-3
    Modify the solver aggressivity =2 (very robust)
    ===> solver type=AMF direct solver
    Is there anything wrong with the setting?
