"The computation failed" when I use Polyflow to simulate filling process of chemical reaction flow
I am using Polyflow to simulate the mould filling process of a chemical reaction flow, but the computation failed. I have attached the listing File, can any one help? many thanks.
  • uxsarahuxsarah Member
    edited November 2018
     Running vof for T within [ 0.000E+00 , 2.000E+02 ]
      with dT-ini = 1.000E-01,
           dT-min = 1.000E-02, dT-max = 2.500E-01,
      with up to 2000 successful steps,
      ===> Starting VOF
             at T-ini = 0.000E+00
          Initial volume     =  1.4103619E-04 / 4.1392274E-02
     Preprocessors
     Convergence assumed : Rel. var. LT  1.00000E-04
     F.E.M. Task
     Global divergence has occured. Diverg =  0.2000000E+04
        VOF Step #1                                 |   Progress bar(s)  |
          Time               =  0.0000000E+00       |>                   |
          Volume of fluid    =  1.4103619E-04       |>                   |
          Volume filled (%)  =  3.4073070E-01       |>                   |
          Step status : KO
              Solver divergence occured.
             New time step      =  5.0000000E-02
     Preprocessors
     F.E.M. Task
    Divergence detected for field Carbondioxide: iterations cancelled by Expert System
    Divergence detected for field Urethane: iterations cancelled by Expert System
          Step status : KO
             New time step      =  2.5000000E-02
     Preprocessors
     F.E.M. Task
               *** WARNING *** from [fpow]
              Negative local temperature for power law. Stop.
               *** WARNING *** from [mat162]
              Evaluation of the reaction rate has failed. Stop.
               *** WARNING *** from [MATRIX]
              Information about the above trouble...
              for problem Reaction rate 2D
              on domain: SURFACE_BODY.
                near location : ( 0.23946E+00 ,  0.92221E-01 )
          Step status : KO
             New time step      =  1.2500000E-02
     Preprocessors
     F.E.M. Task
    Divergence detected for field Urea: iterations cancelled by Expert System
          Step status : KO
             New time step      =  6.2500000E-03
     Preprocessors
     F.E.M. Task
          Step status : KO
             New time step      =  3.1250000E-03
         *  Summary of the simulation  *
            The computation failed.
         *  Expert tool diagnostics  *
         Computation can not start, time step becomes too small at the first
         step.
         Maybe there is a problem is your set up. Please, review it.
         Out of convergence disk
         The problem F.E.M. Task     has not converged.
         *  Expert tool suggestions  *
         A serious internal error has occured (in printEndOfVof).
         Please, contact Ansys Polyflow support, and send us, if possible the
         mesh, data and listing files.
         We apologize for the inconvenience.
    Is there anything wrong with my folling settings?
    VOF iterative parameters:
    Initial time value =0
    Upper time limit= 2.000E2
    Initial value of the time step= 1.000E-1
    Min admissible value of the time-step = 1.000E-2
    Max admissible value of the time-step = 2.500E-01
    Accuracy of VOF scheme =2.500E-01
    Max number of successful steps =2000
    <!-- [if gte mso 9]>
    <w:LsdException Locked="false" Priority="72" Name="C
