I don't think so. The best approach will be to save the session with a different name and then delete all the bits you don't want from the project page. Do NOT go into the directory structure and delete files as that can cause problems later.
Do you want to move the solver bit (ie Mechanical, Fluent etc) or an entire workflow?
an entire workflow
Thank you for your answer. I will try this approach.
