Preserving the Scoping of Named Selections & Coordinate Systems when Adding / Modifying Input Meshes
I am working on assembling a model of the spine, ribcage, and pelvis in ANSYS 18.0. I first imported just the spine mesh using the FE modeler system in workbench , and then connected this to a static structural system. Within mechanical, I created named selections from nodes to select measurement points on each bone. I also created vertex based local coordinate systems on different sections of bone.
After the selections and coordinate systems were defined, I next added another input mesh (both of these are .inp files) of a pelvis, but when this was completed and I reopened the mechanical interface, the scoping of these named selections (node based) and local coordinate systems (vertex based) were both lost.
Is there a way to retain the scoping of these selections while still adding or modifying input meshes? I am able to keep all input node numbers consistent within each .inp file.
I also was trying to follow along with this page:
https://www.sharcnet.ca/Software/Ansys/17.0/en-us/help/wb_sim/ds_Mesh_Numbering.html
but was unable to use mesh numbering to retain my named selections/coordinate systems.
Any help on this would be greatly appreciated, and I'd be happy to help with more information if need be.
  • sathyasathya IndiaMember
    edited January 2019
    If you can share the second .inp(pelvis mesh alone) like below, I hope you can retain the existing datas.
    Sharing two different External models
  • dOBLdOBL Member
    edited January 2019
    Thanks, this does work in terms of importing all of the meshes, but I am unable to preserve the components of the spine input mesh. Where I split the vertebrae up into several components, it takes each bone as one entity. Is there any way to do keep the component separation through the External Mode --> Static Structural method?
    Christian
    edited January 2019
    Can you share the mechanical window screenshot (with the components you are mentioning) before and after importing of 2nd .inp file?
