Sizing on Ansys Workbench 19.2
kierankkierank Member Posts: 1
I got the 19.2 student version to download fine, but when I run the workbench, the tabs and fonts are so small. How do I fix this? I have added a picture of the problem:
  • dsurendrdsurendr Irvine, CAPosts: 82Member
    edited January 2019
    Hello
    It seems you are using 4K resolution display. ANSYS applications do not scale well on 4K resolution yet.
    You can try this workaround:
    A workaround that others report as working fine is to reduce the resolution (try 1920 x 1080) and then also adjust your windows scaling settings, reduce the scaling to 100%.
    Reboot/log out and log in after making the resolution changes.
    Also try on the ANSYS Product (Workbench in this case) shortcut and select Properties. Under Compatibility select "Disable display scaling on high DPI settings".
    Divya
  • labyrinth01labyrinth01 Posts: 3Member
    Hey, I am using Mac-pro Windows OS. I fixed this problem by changing properties of RunWB2.exe. Please have a look a the picture below.
