Bolt pretension causes high compressive stress exceeding UTS but deformation is only 0.2mm
I have done a static structural analysis of an assembled component that uses bolt connections and welds. I had defined two type of loads, 1.Bolt pretension 2.External load as force.
I have defined bonded contacts for all the bolt, nut interfaces and the surfaces that were mated for assembly. The results were not as expected. I got a peak von mises stress of 960MPa, near the bolt hole region, whereas the ultimate strength of my material (structural steel in ansys) is only 460MPa.
Von mises value exceeding UTS
NOTE-1: I have previously defined frictional contacts for bolt head and nut head interfaces, but it resulted in DOF limit exceed error and newton raphson residual showed  my elements flew off in space. So i switched all my contacts to bonded type and got this undesired result. I am sure the component wont fail (from the experiments) that is it can never develop this high stress value.
NOTE-2: I have redesigned my original component with a generic model and have used it for this post
Please direct me to find where the problem is in this analysis, i have attached with this the post my archived workbench file
«1
    edited February 2019
    Hello Gopinath,
    You will get much better results using Frictional Contact under the heads and nuts than Bonded Contact, but you have to check that the contacts are closed. Put a Contact Tool under the Connections folder and Generate Initial Contact Status. If any contact is not closed, you have to take corrective action such as setting Adjust to Touch on that contact.  You also turn on Auto Time Stepping and set the Initial Substeps to a large number like 100 to give the solver a chance to establish contact before too much bolt pretension has occurred. That will prevent the Exceeded DOF Limit error you are seeing with the parts flying out into space.
    Then you have to wait longer for the solution for Frictional Contact because the solver has to iterate to find the contact and it doesn't have to iterate for a Bonded Contact.
    To reduce the node count in the mesh you should learn to take advantage of symmetry. The load and geometry are almost symmetric. I expect you can ignore that the base plate is wider on one side than the other. Do some geometry simplification. Delete all the small blends on the part with the cylinder except for those on interior corners. Delete all the blends off the screw and nut heads. You are adding a lot of nodes to the model for very little benefit. It will solve faster is there are fewer nodes.
    After making those changes, the mesh reduces from 1.8 million nodes to 0.6 million nodes.
    Regards, Peter
  • GopinathVGopinathV Member
    Thank you Peter...i shall work on the geometry simplification part. Although i would find the frictional contact definition quite challenging . i had an instinct that my contact definition is what kept causing me too much troubles, but if frictional contacts definition is the correct methodology to constrain my model then i shall work my way into that. i shall update this after i try again with frictional contacts.Thanks again
    And your suggestion about the symmetry of the model, did you mean to suggest me to slice up my whole assembly along the XY plane into half?
    Yes, down the center of the main bracket.
    Updating Bonded Contact to Frictional Contact is as simple as selecting all the bonded contacts in the Outline, and using the pulldown where it says Bonded and picking Frictional and entering a COF.
    It dint strike my mind at first, but i am surprised when u did remove those blends off the fasteners and pin, and remeshed it. May i know how u did that?
    To delete a face in SpaceClaim, click the face and hit the delete key. If it can, SC will trim the adjacent faces to close the gap.
    Good to know about this. Thank you peter.
    One other thing, i shall define frictional contact between surfaces of bolt head and nut head with its components in contact, but do i define all other surfaces in contact to be bonded? For example, the cylindrical pin and the bracket are not supposed to be separated after they are being fastened by bolts, so the surface between pin and bracket should be defined a bonded contact and all other surfaces that have been mated during assembly of components should also be defined bonded contacts. Am i right here?
    The only bonded contact would be nut to bolt, except for the bolts that go into the bracket where there is no nut, those could be bonded. There is an alternate approach that simulates threads, but that might be a topic for another post.
    All the faces being clamped together by the nuts and bolt heads should be frictional contact.
    OK thank you again.
    I have also modeled weld between bracket's side edge and support plate. What type of contact would they have between their surfaces?
    I never thought the contacts in the analysis would be this difficult and important!
    Yes, bonded contact is appropriate for each weld face to the mating part. I forgot about those!
    Thanks once again. I shall update this post if i find trouble establishing initial contact with frictional contacts
    Peter, after implementing your suggestions on frictional contacts and giving sufficient substeps for loads steps, mu solution converged. Yet, i still have peak stress values around the bolt holes to be exceeding the uts value.
    one important thing to be noted is that my total deformation doesn't exceed 0.2mm while the von mises stress is around 700MPa.
    Can someone explain what could possibly have gone wrong?
    Which holes have the high stress? Are you sure it is the hole and not the bolt head. You can ignore high stress under the bolt head where you left a sharp interior corner as the real bolts have a small radius that limits the peak stress.
    If it is the through holes, you should confirm that there is no dependence of the result on element size by reducing the element edge length by a factor of 2 around that hole edge and the bolt head that has frictional contact with the face.
    If it is the threaded holes, you can change from bonded contact to frictional contact and add the Geometric Modification of Bolt Thread to the contact definition and use mesh controls to have element size no larger than 1/4 of the pitch on those faces.
    If the true solution is that the stress exceeds UTS and you don't want that, then you have to redesign the assembly and use more bolts.
    If the true solution is that the stress exceeds the UTS and you want to see the plastic deformation, then add plasticity to the material model and let the material stretch after it reaches its Yield Strength. The simplest plasticity material model is Bilinear Isotropic Hardening. Enter the Yield Strength and type 0 for the Tangent Modulus. This defines an Elastic Perfectly Plastic material.
    Peter, to answer your first question, the through holes have these high stress values and not the threaded holes.
    As for the second question, yes i am sure the holes does experience high stress and not the bolt head. Rather an even more peak stress of 900MPa occurred on a circular edge of bolt shank face where i had split a face along the lengh of bolt to differentiate the shank face (to define pretension load) and threaded part (modelled as smooth cylindrical surfaces)...i shall, however, try on the mesh dependence and i am also sure that plastic deformation cannot happen
    • What preload are you using?
    • What is the fastener size and grade of material?
    • What is the torque spec you specify for tightening that fastener?
    You could add a washer to the design to spread the load over a larger area.
    I had used M20, M16 and M14 bolts of grade 10.9. Material selection ISO R898..i created the engineering data for that material from a data sheet..other than isotropic coefficients, density and strength values i had also defined bilinear isotropic hardening properties with yield strength and 3% of young's modulus as tangent modulus. All preload values were defined according to specified values of pre-torque for metric bolts. Preload values are: M20 - 125kN; M16 - 96.87kN; M14 - 71.43kN.
    Also i have attached a screenshot showing the peak stress value of around 700MPa and exactly where it does occur on the bolt hole region (of the front face of bracket), for reference
    It looks like you are showing a hole that in the real part would be tapped and have threads, but in the model has bonded contact. Am I right?
    oh ok peter, i knew about bolt section method previously. but i thought creating a MPC bonded contact instead would reduce my computation time.
    And yes i will try that option now.
    But one question though; i had used a M20 bolt in the design and had defined 125kN of preload...how high value of stress is expected out of pretension bolt loads?
    And regarding the bilinear isotropic hardening, i should define the materials yield strength value and tangent modulus be assigned zero right? if that is the case, should i turn on large deflection in the analysis settings?
    Yes, MPC bonded contact reduces computation time and is a less accurate method of representing a threaded fastener connection.
    Using linear materials reduces computation time and is a less accurate method of representing stress in the model that exceed yield strength.
    If you have checked that you have a sufficient length of thread engagement to avoid stripping the threads when applying the correct preload, then you are done. You could make an element selection that selects all the elements in that part except for the elements on the face of that hole. That is one way of ignoring elements you don't care about because you have a good reason to ignore them.
    If you change the material of that part to a bilinear isotropic hardening plasticity model with zero tangent modulus, you won't have any stress above yield strength anymore (except for extrapolation to the nodes, see ERESX command). Whenever you turn on plasticity, you should also turn on Large Deflection.
    You could also change the contact to Bolt Thread geometry and put a lot more elements on the hole face. You might still exceed the UTS with a linear material, in which case, you can use the nonlinear material.
