Heat transfer through pipe wall
I am trying to simulate in 3D a copper pipe passing through water maintained at 3 degrees Celsius with air passing through the pipe. The air at inlet is 20 degrees and enters at 0.3m/s.
It can be assumed the pipe wall temperature is 3 degrees but when I try create this simulation the pressure outlet requires me to define a temperature when this is actually what I am trying to calculate!
What is the best way to set this up, I have tried modeling the pipe wall with a frozen fluid volume and I have also tried to model just a soli cylinder and said the fluid to be air and assigned a wall to the outer of the volume but neither appear to work to tell me what the temperature is at the end of the pipe!
Any advice would be appreciated or if there is any examples you can upload that would also be great just so I can understand how to do this simple simulation!
    edited February 2019
     Hello Colin,
    The quickest way to model this is to use an axisymmetric model. Just draw the a rectangle for the air along the X axis on the +y side to represent a radial slice.
    The outlet asks what the Backflow temperature is, not what the temperature of the outflow, that will be calculated.
    Any CFD experts with improvement suggestions are most welcome to reply with comments.
  • seeta guntiseeta gunti Member
    Here are the two tutorials on Conjugate heat transfer which give the heat transfer of fluid and solid.
    At the outlet, you need to give the boundary condition. Fluent will ask for backflow temperature at the outlet.
  • colinthocolintho Member
    Thanks for running through that tutorial Peter, I have managed to do the pipe in 2D and have since modeled it in 3D too and got it to work properly!
    Also thanks Seta for those tutorials!
  • how did you solve the problem, me too i'm struggling please some help and thank you @colintho
  • @Abdmen
    Please reply with a specific issue that you are struggling with.
  • @peteroznewman
    I want to simulate water flow inside a pipe of steel.covered with concrete, i do the simulation in 2D. I create one part, i identify the interfaces between water and betwen the other materials, when going to the fluent setup for the interface between the pipe and water the material is steel, but when runing the simulation the results are not good it temperature of water remain constant the same for all other materials. Here are some picture of my problem and thank you so much
    edited October 19
    @Abdmen
    I suggest you start a New Discussion. It is confusing because your problem is different than the original poster's problem.
    Please reply with a simple hand sketch of the water, steel and concrete cross-section. Label the temperature and flow rate of the water. Label the thermal boundary condition on the Concrete. Mark the radius of the water, OD of the steel and OD of the concrete. Mark the length of the pipe.
    I assume you are looking for a steady state solution.
    You should make this model as an axisymmetric model. That means the pipe centerline lies along the X axis and you draw a rectangle for the radial dimension of the water on the +Y axis. Make another rectangle for the steel, then a third rectangle for the concrete. Don't draw any rectangles on the -Y side of the X axis.
    In your replies, if you need a screen snapshot, use a screen capture program like Snipping Tool instead of using your cellphone camera.
  • @peteroznewman
    its just a simple model which doesnt work, my real one is not symetric, it's composed of multiple layers, with this one which is simple i dont get good results always the energy residual starts from 10e-16. moever the interface between the pipes and concrete is generated in setup as interior i dont know why.
    thank you sir for your help
