Issue with CFX solver in Learning Hub's WS01-Mixing-Tee exercise
Risto86Risto86 Portland State UniversityMember
I'm attempting to make my way through some of the learning hub courses as I await my university to license our sponsored software package, using the free student edition in the meantime.
I've gone through this exercise numerous times, starting from scratch twice, and I continue to get the error notices "Non-zero exit code 2" and on the CFX solver outfile, "Solver exited with return code 1".
My understanding is that the student version has a node/element limit of 152k, which was never approached but I still received the error. I went back and applied mesh sizing limits to reduce the mesh to below 32k and I still receive the error.
Is the issue a misapplication somewhere in the meshing or setup process? An issue with my computer, or simply that I'll need to have the licensed academic version to run the solver on this problem?
Attached file note: v0 is before mesh adjustment, v1 is after using sizing to reduce element count.
Will update if I find a solution before someone responds.
Thanks!
    edited February 2019
    You've got a 512k cell count limit, so should be fine with the tutorials. Are there any warnings/messages before the exit code? Those tend to be more useful. Also check disc space both in the working directory but also scratch (set in Workbench -> Tools).
    Are you seeing any license error messages in the CFX out file?
  • Risto86Risto86 Portland State UniversityMember
    I recorded my desktop as I ran the solver so you can see what I see. I've also attached the CFX solver out file as copied into notepad, which does show a warning on the top which I don't understand. I monitored my computer cpu usage and memory during a subsequent run, and it didn't get anywhere near maxed out. (edit with attached mp4 pending)
    Within (tell me if this is the right place to look to check disc space) Workbench->Tools->Options->Mechanical ADPL->Default Memory: 1024mb; Workspace Memory: 1048mb.
    I haven't seen any notice of license errors in the outfile, unless I somehow overlooked it multiple times
    For the disc space just use the File Manager/Explorer and check for free space.  As staff we can't open attachments so can't review the out file.
    That's unfortunate, I'll take it the video will be a waste to upload... I have 676 GB of free space on my computer
    The warning at the top of the file is "Warning! Revision is over 16 characters long 39"
    Then at the bottom I see: "An error has occurred in cfx5solve: The ANSYS CFX solver exited with return code 1. No results file has been created."
    Full out file as below:
    Warning!
     This run of the CFX Welcome to ANSYS Student Discovery Live Solver
     started at 02:55:06 on 12 Feb 2019 by user risto on DESKTOP-17EOLLP
     (intel_xeon64.sse2_winnt) using the command:
      "C:\Program Files\ANSYS Inc\ANSYS Student\v192\CFX\bin\perllib\cfx5solve.pl"
        -batch -ccl runInput.ccl -fullname CFX_003
      Point Releases and Patches installed:
      Academic Student Release 19.2
      FENSAP-ICE Release 19.2
      AIM Academic Student Release 19.2
      AIM Release 19.2
      Discovery Release
     Setting up CFX Solver run ...
    CFX Command Language for Run
     LIBRARY:
       MATERIAL: Water
         Material Description = Water (liquid)
         Material Group = Water Data, Constant Property Liquids
         Option = Pure Substance
         Thermodynamic State = Liquid
         PROPERTIES:
           Option = General Material
           EQUATION OF STATE:
             Density = 997.0 [kg m^-3]
             Molar Mass = 18.02 [kg kmol^-1]
             Option = Value
           END
           SPECIFIC HEAT CAPACITY:
             Option = Value
             Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
             Specific Heat Type = Constant Pressure
           END
           REFERENCE STATE:
             Option = Specified Point
             Reference Pressure = 1 [atm]
             Reference Specific Enthalpy = 0.0 [J/kg]
             Reference Specific Entropy = 0.0 [J/kg/K]
             Reference Temperature = 25 [C]
           END
           DYNAMIC VISCOSITY:
             Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
             Option = Value
           END
           THERMAL CONDUCTIVITY:
             Option = Value
             Thermal Conductivity = 0.6069 [W m^-1 K^-1]
           END
           ABSORPTION COEFFICIENT:
             Absorption Coefficient = 1.0 [m^-1]
             Option = Value
           END
           SCATTERING COEFFICIENT:
             Option = Value
             Scattering Coefficient = 0.0 [m^-1]
           END
           REFRACTIVE INDEX:
             Option = Value
             Refractive Index = 1.0 [m m^-1]
           END
           THERMAL EXPANSIVITY:
             Option = Value
             Thermal Expansivity = 2.57E-04 [K^-1]
           END
         END
       END
     END
     FLOW: Flow Analysis 1
       SOLUTION UNITS:
         Angle Units = [rad]
         Length Units = [m]
         Mass Units = [kg]
         Solid Angle Units = [sr]
         Temperature Units = [K]
         Time Units = [s]
       END
       ANALYSIS TYPE:
         Option = Steady State
         EXTERNAL SOLVER COUPLING:
           Option = None
         END
       END
       DOMAIN: junction
         Coord Frame = Coord 0
         Domain Type = Fluid
         Location = Fluid Domain
         BOUNDARY: inlety
           Boundary Type = INLET
           Location = inlet y
           BOUNDARY CONDITIONS:
             FLOW REGIME:
               Option = Subsonic
             END
             HEAT TRANSFER:
               Option = Static Temperature
               Static Temperature = 10 [C]
             END
             MASS AND MOMENTUM:
               Normal Speed = 5 [m s^-1]
               Option = Normal Speed
             END
             TURBULENCE:
               Option = Medium Intensity and Eddy Viscosity Ratio
             END
           END
         END
         BOUNDARY: inletz
           Location = inlet z
             FLOW REGIME:
               Option = Subsonic
             END
             HEAT TRANSFER:
               Static Temperature = 90 [C]
             END
             MASS AND MOMENTUM:
               Normal Speed = 3 [m s^-1]
             END
             TURBULENCE:
             END
           END
         END
         BOUNDARY: outlet
           Boundary Type = OUTLET
           Location = outlet
             FLOW REGIME:
               Option = Subsonic
             END
             MASS AND MOMENTUM:
               Option = Average Static Pressure
               Pressure Profile Blend = 0.05
               Relative Pressure = 0 [Pa]
             END
             PRESSURE AVERAGING:
               Option = Average Over Whole Outlet
             END
           END
         END
         BOUNDARY: wall
           Boundary Type = WALL
           Location = F29.40,F30.40,F31.40,F32.40,F33.40
             HEAT TRANSFER:
               Option = Adiabatic
             END
             MASS AND MOMENTUM:
               Option = No Slip Wall
             END
             WALL ROUGHNESS:
               Option = Smooth Wall
             END
           END
         END
         DOMAIN MODELS:
           BUOYANCY MODEL:
             Option = Non Buoyant
           END
           DOMAIN MOTION:
             Option = Stationary
           END
           MESH DEFORMATION:
             Option = None
           END
           REFERENCE PRESSURE:
           END
         END
         FLUID DEFINITION: Fluid 1
           Material = Water
           Option = Material Library
           MORPHOLOGY:
             Option = Continuous Fluid
           END
         END
         FLUID MODELS:
           COMBUSTION MODEL:
             Option = None
           END
           HEAT TRANSFER MODEL:
             Option = Thermal Energy
           END
           THERMAL RADIATION MODEL:
             Option = None
           END
           TURBULENCE MODEL:
             Option = k epsilon
           END
           TURBULENT WALL FUNCTIONS:
             Option = Scalable
           END
         END
       END
       OUTPUT CONTROL:
         MONITOR OBJECTS:
           MONITOR BALANCES:
             Option = Full
           END
           MONITOR FORCES:
             Option = Full
           END
           MONITOR PARTICLES:
             Option = Full
           END
           MONITOR POINT: p inlety
             Expression Value = areaAve(Pressure )@inlety
             Option = Expression
           END
           MONITOR POINT: p inletz
             Expression Value = areaAve(Pressure )@inletz
             Option = Expression
           END
           MONITOR RESIDUALS:
             Option = Full
           END
           MONITOR TOTALS:
             Option = Full
           END
         END
         RESULTS:
           File Compression Level = Default
           Option = Standard
         END
       END
       SOLVER CONTROL:
         Turbulence Numerics = First Order
         ADVECTION SCHEME:
           Option = High Resolution
         END
         CONVERGENCE CONTROL:
           Length Scale Option = Conservative
           Maximum Number of Iterations = 100
           Minimum Number of Iterations = 1
           Timescale Control = Auto Timescale
           Timescale Factor = 1.0
         END
         CONVERGENCE CRITERIA:
           Residual Target = 1.E-4
           Residual Type = RMS
         END
         DYNAMIC MODEL CONTROL:
           Global Dynamic Model Control = On
         END
       END
     END
     COMMAND FILE:
       Version = 19.2
       Results Version = 19.2
     END
     SIMULATION CONTROL:
       EXECUTION CONTROL:
         EXECUTABLE SELECTION:
           Double Precision = No
           Large Problem = No
         END
         INTERPOLATOR STEP CONTROL:
           Runtime Priority = Standard
           MEMORY CONTROL:
             Memory Allocation Factor = 1.0
           END
         END
         PARALLEL HOST LIBRARY:
           HOST DEFINITION: desktop17eollp
             Remote Host Name = DESKTOP-17EOLLP
             Host Architecture String = winnt-amd64
             Installation Root = C:\Program Files\ANSYS Inc\ANSYS Student\v%v\CFX
           END
         END
         PARTITIONER STEP CONTROL:
           Multidomain Option = Automatic
           MEMORY CONTROL:
           END
           PARTITION SMOOTHING:
             Maximum Partition Smoothing Sweeps = 100
             Option = Smooth
           END
           PARTITIONING TYPE:
             MeTiS Type = k-way
             Option = MeTiS
             Partition Size Rule = Automatic
           END
         END
         RUN DEFINITION:
           Run Mode = Full
           Solver Input File = CFX.def
           Solver Results File = \
             CUsers/risto/Desktop/WS01-Mixing-Tee_pending/dp0_CFX_Solution/CFX_0\
             03.res
         END
         SOLVER STEP CONTROL:
           MEMORY CONTROL:
           END
           PARALLEL ENVIRONMENT:
             Number of Processes = 1
             Start Method = Serial
           END
         END
       END
     END
    Solver
    ANSYS(R) CFX(R) Solver
    End of solution stage.
     For CFX runs launched from Workbench, the final locations of directories
    and files generated may differ from those shown.
    This run of the ANSYS CFX Solver has finished.
    Looks consistent: are there any other error messages printed in the CFX console? Can you try running the definition file in CFX Standalone? Can you attached the definition file here?
    I'm sorry, can you explain what you're asking for, or point me to an explanation of how to do it?
    You have a definition file created in the workbench directory (name*.def). Now Start CFX Solver out of the Workbench: Start Programs, CFX, then CFX Solver from the CFX Launcher Panel, define Run, give the path to the definition file and start.
    I apologize, it took me a couple of days to get back to this.
    I tried your suggestion, and the result is exactly the same in the Solver Manager, but I do have a shell window with this additional output:
    Warning!
    2019/02/14 19:400    INFO                Demo license file C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\student.lic exists.
    Warning!
    Unable to assign product revision id.
    Use of uninitialized value $data_items{"Application.Buildinfo"} in sprintf at C:\Program Files\ANSYS Inc\ANSYS Student\v192\CFX\bin\/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
    Use of uninitialized value $data_items{"Mesh.Elements"} in sprintf at C:\Program Files\ANSYS Inc\ANSYS Student\v192\CFX\bin\/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
    Use of uninitialized value $data_items{"Mesh.Faces"} in sprintf at C:\Program Files\ANSYS Inc\ANSYS Student\v192\CFX\bin\/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
    Use of uninitialized value $data_items{"Mesh.Nodes"} in sprintf at C:\Program Files\ANSYS Inc\ANSYS Student\v192\CFX\bin\/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
    Use of uninitialized value $data_items{"Mesh.Zones"} in sprintf at C:\Program Files\ANSYS Inc\ANSYS Student\v192\CFX\bin\/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
    Use of uninitialized value $data_items{"Session.TotalCpuTime"} in sprintf at C:\Program Files\ANSYS Inc\ANSYS Student\v192\CFX\bin\/perllib/CFX5/Simulation/Configuration/APIP.pm line 119.
    Can you please for debugging purposes create a simple pipe with velocity inlet, wall and pressure outlet, carry out that steady simulation and check if it works. Thanks
    It seems that there was an issue with the geometry. I created my own version of the tee in SpaceClaim and the simulation ran perfectly!
    Nice. Please mark this as resolved.
