Could not create file required to determine products to be displayed in the License dropdown list
The following error pops-up when opening "Mechanical APDL Launcher"
error window
Things to note about my installation:
- I am able to execute Icepack and SpaceClaim without any issues
- I have installed all ANSYS programs on the D: drive of the computer, not the C: (main) drive
- I am running Windows 10
Thank you!
  • tsiriakstsiriaks 3240 El Camino Real #290, Irvine, CA 92602Member
    edited February 2019
    Hi flobo,
    Launch the Client ANSLIC_ADMIN Utility v19.3 with "run as administrator" > Specify the License Server Machine > Add Server Machine Specification > in the Hostname 1 box , type the hostname of the license server > OK
    Does this help ?
    Win
  • floboflobo Member
    Win,
    When I access the client, I already have a license listed.
    I tried erasing it and writing it again... I get the same issue...
    Any other thoughts?
    Also... keep in mind... that only the mechanical suite seems to not work for some reason. I can run SpaceClaim, Icepak, and Fluent...
    open CMD Prompt, then issue the following command
    set
    and post the entire output of it here.
    Also, go to your installation directory (e.g., C:Program FilesANSYS IncShared FilesLicensing) , then open ansyslmd.ini with any text editor app like notepad and post its content here.
  • floboflobo Member
    Your ANSYSLIC_DIR is set to a wrong path. It should be
    ANSYSLIC_DIR=D:ANSYS IncShared FilesLicensing
  • floboflobo Member
    I think I found the culprit
    For some reason, I cannot change the path during installation.
    Could this be a factor of pre-sets of previous installation?
  • floboflobo Member
    I believe I have solved all of the problems. Just want to share the solution to that last issue I had.
    In order to change the default directory: ALL PREVIOUS INSTALLATIONS OF LIC. MANAGER MUST BE REMOVED
    In some instances, that includes removing or deleting the license manager services:
    If this cannot be performed using task manager, it can be done using the command prompt:
    SC DELETE servicename
    In the case of the services shown above
    SC DELETE "ANSYS, Inc. License Manager"
    SC DELETE "ANSYSLicensingTomcat"
    Note that the " " may or may not be needed...
    After, reboot/restart your machine!
    Thank you for sharing.
    Yes, this is correct, you should remove this and ANSYSLIC_DIR , so that you could change the installation path.
