defining a plane as New Surface for a 2D geometry
I have a 2D model in Fluent, and I have calculated the model. In processing the data, I am interested in plotting the calculated results on a smaller window/plane rather than on the whole geometry. But I can not define a "plane" using defining "new surface". Please see the figure below: The green area is the 2D (axi-symmetric) geometry. The "plane" option is inactive. and I want to plot the results for a rectangle area similar to the red rectangle I draw on the geometry.
    edited February 2019
    Perhaps you can do that by clipping the surface two or three times
  • ZariZari Member
    edited March 2019
    Thank you so much dear Amine,
    Now I learned it. I did it in two steps, once clipped in X-coordination and then on y-coordination. Since other users may have the same question, I attached the steps in the figure below.
    Now I can plot the results only on that area. But I cannot write it to a file. Do you know how can I do it? For instance, as the figure below shows, I have the plotted swirl velocity distribution on that area. I also have the data from experiments for same area. I need to export the model results (x, y, velocity) from the model (as from the figure below) to a file and compare it with experiments.
    Thanks for your help,
    Zari
    edited March 2019
    thanks zari for updating solution.
    can you please mark this as 'is solution' to help others on forum.
  • ZariZari Member
    edited March 2019
    Sure.
    Then I asked another question in continue, about exporting field data from the clipped surface. Should I start a new discussion? Or it could be seen as it is now?
    edited March 2019
    You can try export it as ASCII file.
