change temperature scale in ansys apdl
jainam3112jainam3112 Member Posts: 3
i am currently doing thermal - transient analysis in ansys apdl. i want to change temperature scales to my desire ranges and here as per picture you can see that we are getting 9 temperature range but as per my requirment i want to add 12 temperature scale . so, anyone know how to solve this problem ,then please help me.
thank u !
  • mrifemrife PHLPosts: 233Forum Coordinator
    edited March 2019
    Jainam3112
    Since you are using the MAPDL GUI use the following: PlotCtrls -> Style -> Contours.  Then most likely Uniform Contours (not sure if you want uniform or non-uniform spacing on the contour plot) and change the number of contours to 12.  And replot.
    Mike
